COMMANDR
Interesting new white LED driver I just ran across, what do you think.
0.9V- Boost Driver for White LEDs PR4401/4402
The core of this driver consists of a step-up converter with current output, which provides an output voltage of typically 3.6 V for white LEDs. The input voltage can be as low as 0.9V, thus allowing a single cell battery operation.
For operation of up three LEDs is only one external component needed, which is an inductor. It is recommended to use an inductor value of 22 µH for a maximum battery lifetime ( more than 70 hours with an AA alkaline battery). With a 10 µH coil higher currents can be reached for maximum brightness of the white LEDs. The battery current will be reduced to less than 10 µA in case that the supply voltage drops to avoid a deep discharge of the battery.
Two different versions are available, the PR4401 offers a maximum current of 22mA, the PR4402 drives up to 40mA. Both versions are delivered in a compact SOT23-3 package, for size-sensitive applications also chip on board assembly is possible. Both LED drivers offer a low-cost three-component-solution for example for small LED flash lights or torches.
http://www.globalspec.com/Supplier/Profile/PREMASemiconductor/
Look under Product Announcements
Gary
Gary
