Britelumens
Sorry, I didn't notice you used the shark with remora. :banghead:
Did you measure output current (going through the led) on high?
Hi Fred,
Yup, 0.86 amp ;)
With regards,
Jo @ Britelumens
The Shark does not have thermal protection whats happening is your overheating a component(s) on the board causing the shark to shutdown.
I encountered that when running it on the highest setting, and was suspecting it as I did not remembered that the SHARK driver has any thermal protection. It's the switching IC that overheat cause the shutdown, so only momentary on the highest is recommended for this one.
When I built the run of Ostar powered MagLites I was using the MaxFlex set for 1000ma and was pulling 2.2amps on 3x 17670 cells and even with all the mass of the maglite and HUGE heatsink the light got hot QUICK.
It does heat up quick on the Ostar when running at highest setting no matter how big the heat-sink is going to be. It just a matter of time.
Momentary and sensible usage beat any heat-sink design I think :)
Now if you used 4 cells you may be safe but 3 cells is pushing it as you found out :)
I believe you are referring to the stress on the batteries life and not the cause of the thermal shutdown of the SHARK driver?
If it hasn't been done before there may possibly be a reason why :)
I'll reserve on this one :) but if you don't attempt. Would you have a chance to know WHY? :thinking:
That is when I see one light host with so many different build where members here progress to make a better light when reading about physical constraint or limitation like this for instant. That's positive.
After taking off the depth of the reflector, with limited rooms to work with. I'm actually quite please to be able to squeeze 1 SHARK, 1 Remora , with a short burst of more than 15W on an Ostar and more than 40 mins and some on medium. I could not ask more on this small light.
I appreciate your comment though.
With regards,
Jo @ Britelumens
Mac
Joe the problem here is with the batteries. R123's should not be used at 2 amps for safety reasons.
As for my 4 cell comment that was made towards the batteries and shark. With the voltage sag on 3 R123's at 2 amps the shark is probably only seeing around 10v and then having to boost that to around 21v is not recommended and is the reason why it shuts down in only a couple of minutes. With 4 cells you have better efficiency and the driver does not have to work as hard. Also the current draw of the batteries decreases as well.
Mac
Hi Jo
I had an ostar 1.25 mag that I used a blue shark with remora powered by 4x 17670 and after about ten minutes the light shut off surprising but as mentioned on medium no problem.
Dave
Hi Jo
........about ten minutes the light shut off surprising..........
Dave
