knot
Banned
RC-C3 Cree LED Flashlight Gray (1.3V~4V CR123A) what does it mean? A cr123 battery isn't going to run down to 1.3v and the circuit provide a boost - and a AA doesn't look like it's going to fit.
What's the problem? If the battery cannot support the charge, the light will go dim and it would then be time to replace the batt.
Probably means it can run on CR123As or RCR123As.
Hmmmm...... seems to me this merely states that the circuit will support voltages from 1.3V-4V, and that it comes standard with a battery tube that fits CR123 batteries.
Possibly, if somebody had a 1xAA battery tube that happened to fit this light... they would be able to run it that way also.... a nice thing to know.
My only hesitation would be the upper limit of 4 volts, as it seems that most RCR123 batteries come off the charger at closer to 4.2 V, but maybe that's not a problem with this light.
RCR123 can be 3v or 3.7v.
The 3.7v ones will charge to 4.2v but their resting voltage is about 3.8v only. So they should be OK provided they are not used in this light straight off the charger. The extra 0.2v should not harm the light as it is going to drop very soon after turning on.
The 3.0v ones are OK because they only charge up to 3.6v.
For such technical matters I suggest we ask SilverFox. He is the expert.
BTW, there is a thread for the benefits of UK members in The Cafe. Do take a look if you are based in the UK.
