Spacemarine
I've read on CPF that the new Energizer 2500mAh and also the Sanyo 2300 and 2500mAh won't fit into most D-Mags because the cells are slightly thicker than normal AA cells.
When I recieved my bunch of Energizer 2500 I noticed that they really don't fit, unless you use a special trick:
The cells are isolated by a thin plastic layer on the outside, and at one side of the cell this layer wraps around, making the cell a little thicker:
If you turn it into the right position, the cell appears a little smaller:
Here comes the trick: When you insert the cells into the Mag, make sure that the cells are correctly aligned, so they don't touch neither each other nor the wall with their thick side!
Here is the proof that they really fit inside now:
They are fitting a little tight, but you can insert them all the way by nearly no force:
I haven't seen this trick on CPF before. Without it, it's really impossible to insert them into my Mag
Notice: My Mag was custom HA-III black anodized, but I don't think that changed the size of it.
