GLOCK18
Wonder if this would fit the SF m6
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=3544
You should read the post the ? was about the bulb , not fitting the batterys as we know only 3 x 17650 fit the SF M6, the 1185 is perfect as the voltage is from 9.3 to 12 volts flashed at 12.3 I use the W 1185 on many mods using 3 recharables, after charging you need to let them sit for about 30 minutes voltage drops down to 12.1 no flash.
