I've upgraded my workbench microscope lights several times and now it's time for a new pair of lights.
The componenst shown below are Don's 10mm Rebel reflector, PR Can, thin PCB flower cut down to three LEDs, custom heat sink and custom acrylic template.
Not shown is the existing box, 50K audio taper potentiomenter, Shark and other misc components.
Here you can see where the acrylic template is used. It's on top above the LEDs and provides a flat surface for the clamp assembly to hold the thin PCB down flat to the heat sink while the epoxy glue sets up. Below shows the clamp on the head with the heatsink, template and head.
Here is a close up of the template I made for the full 7 Rebel Flower thin PCB.
I bored inside the head to create a little lip for the heat sink to rest on and to set the height of the heat sink, LED and reflector stack up to keep the reflectors close to the lens.
Below is the picture of the heat sink assembly completed along with the glue and fine tip syringe I used to put a small bead of E6000 around the base to hold the reflectors down. Once the E6000 hardened a bit (~20 minutes) I followed it up with a thicker bead around the perimeter of the base of the reflector to make a solid glue joint. I wouldn't rely on the thin bead for long term usage.
Here a look into the front of the head and reflectors.
Some final beamshots after installation. I modified the Shark sense resistor to 0.47 ohms to lmit the high output of the Shark to around 200mA max.
Both on high.
There is also a single 10mm thin PCB on the shoppe for single light applications.
Wayne
Both on high.
Wayne
