AO JAR
- Joined
- Aug 15, 2011
- Messages
- 39
We're busy growing the light bugs.
Nap.
Hi Nap, you think those light bugs have grown big enough to pet yet. LoL
Nap.
Nap, I think those light bugs would be a good .18 lumen flashlight substitute
Good night time light because it gives better depth and hurts your eyes less than red, but still allows you to "preserve" some kind of night vision. Still suffers the same as any monochromatic light though, in that everything looks flat, and can make navigation very difficult... is that object on the ground a sock, or is it a small box of some kind...
.18 lumens is too bright!
Just for reference, what fraction of a lumen are electronics' standby dots? Bright enough to cover with tape at night, to preserve NAV?
FWIW --
Last night, i solved my Sudoku puzzle,
using the Lowest mode on my ZebraLight H51fw headlamp.
That's 0.16 Lumens, according to ZebraLight (out-the-front).
Note: i did NOT have this light on my head. Held it in my left hand, while i wrote with my right hand.
It was certainly *adequate* for this task.
Hope this helps to put things in perspective here.
One of the best posts of the thread so far. It's also worth pointing out that people just get better at whatever they do on a regular basis, vision being no exception.you have to see it for yourself, I don't think there's a way to explain it. What I can say, however is that the first time, it seems like an almost unusable amount of light. Then you try it at night and figure it's probably the least amount of usable light. Then your brain actually adapts to this new lowest amount of light (no kidding, real life example to follow) and then it might even be a little much when it comes on suddenly.
For those who have a hard time digesting this: I have to enter dark rooms every now and then (I don't work there, just repair equipment.) The first time I went in there, I still couldn't see a thing after 20 minutes, and I'm not the only one. With time, the brain figures there's a signal hiding in there somewhere and finally you start seeing more and more. Now I can go in after being on a bright factory floor and see something after a few seconds. If I stay in there for minutes, I can see just about everything there is to see.
I figure the same goes with a dim light (dimmer than 0.2 lumens). The more you have to deal with it, the better you brain will be able to read the signal and the more you can see. Even 0.03 lumens is not completely useless, you just have to get used to it.
It probably won't be long before it's fairly common, but I think some of the lower output lights already have the capability.Note to manufacturers: Bring on 0.01 lumen flashlights LOL
Yeah, but that was because the Solitaire was dim on high!And people used to complain about how dim a solitaire incan was
Get yourself into a place where more of your mind can go to work on what your eyes are seeing.
Since I looked a lot like Kwai Chang Caine when I was younger my best friend used to either call me that or Weedhopper, so I thought for just a second you were talking to me!Follow the dim light first, Weedhopper.
