357mag1
I have an MKN SST-90 flashlight that draws right around 3 amps of current at the tailcap with IMR 26650 batteries. I decided to see how my 18650 batteries would act under this fairly high current draw.
Here are the tailcap amperage readings from multiple tests (about 5-7 per battery). All numbers were recorded where the batteries seem to settle out after a few seconds.
IMR 26650 4000mah (2 tested) - 3A (4.04v)
IMR 18650 1600mah (2 tested) - 3A (4.0v)
AW 18650 2600mah protected (2 tested) - One at 2.7A and one at 2.8A
Ultrafire 18650 2600mah red protected (6 tested) - 5 between 2.58 and 2.62A one at 2.3A
Ultrafire 18650 3000mah protected (2 tested) - 2.35A (2.12A and 3.7v)
Tenergy 18650 2600mah protected (2 tested) - 2.62A (3.8V)
AW (DLG) 17650 1400mah unprotected (1 tested) - 2.7A
AW 17650 1600mah protected (1 tested) - 2.7A
AW 18500 1600mah protected (2 tested) - One at 2.55A the other 2.65A
IMR 18500 1100mah (2tested) - 2.9A
Ultrafire 18350 1200mah unprotected (6 tested) - 2.3A to 2.44A (3.7 to 3.8v) higher volts delivered more current.
IMR 16340 550 mah (6 tested) - 2.65A - 2.72A (4.0v)
AW 16340 Lifepo4 500mah - High mode of light drew about 20ma and was very dim but worked fine in med .88A and Low .27A modes.
AW (DLG) 14500 700mah unprotected (2 tested) - 2.2A (3.78v)
AW 16340 750mah protected (5 tested) - 2.2A (3.78v)
Ultrafire 16340 880mah (3 tested) - 1.85A (3.6v)
Battery Station 900mah (3 tested) - 1.44A, 1.48A and 1.64A (3.5v)
All batteries were almost new with very few hours on them.
Hope people find this half as interesting as I did taking the readings.
