Guy's Dropper
I'm making a mountain bike light for someone. See http://www.candlepowerforums.com/vb/showthread.php?p=3199156#post3199156
I have 12 18650 batteries, some of which I plan to use as a power source. I have a cheap charger that will charge individual batteries, but then I will need to set up the battery holder so that the batteries can be easily removed. Should I instead build a charger into the battery case?
Most importantly, is there a cheap way of making/buying some sort of indicator so that he does not overdischarge the batteries?
