Phased_Array
I received my 2-3D Malkoff 'Drop-In' and thought I'd try it in my homemade 1D Mag-Lite running on a couple AW14670's in parallel. Packs a lot of punch in a small package, but still has a decent heft to it. SMO aluminum reflector helps with the throw. In using it, it's a natural for a endcap click switch with it's small grip length.
Temporary aluminum reflector from my parts drawer, not quite laser beam performance, are there any LED optimized machined reflectors out there?
I drilled two holes thru the switch plastic to insert/secure the LiIon's.
Twin AW 1100mAH 14670's.
As is it has a good hot spot, and very useable side spill.
