Hooked on Fenix
- Joined
- Dec 13, 2007
- Messages
- 3,133
I went to the Carmel Mountain Costco in Poway, California and found a two pack of solar powered 1 watt l.e.d. flashlights for $22.99. They had a whole crate of them. I actually had to ask a worker what the price was because it wasn't listed yet. These are branded Hybrid Light SolarLite with battery backup. They claim that the solar batteries will hold a charge for over 3 years, and that you get 10 hours of light on a full solar charge. They also claim to be 40 lumens each light and be waterproof to 80 feet. They also claim that it floats. I had to buy them and see if they were any good.
Lumen output was overstated by quite a bit. Output compares to that of a stock 2AA Minimag, around 10 lumens. It has a wider, more usable beam pattern than a minimag though.. The l.e.d. isn't a Luxeon. I don't know what it is. It looks similar to the 10mm l.e.d.s put in the Nite Ize drop in for large maglites but seems about 5 or 6mm. User interface isn't my favorite. One push turns the light on using solar battery power. The second push is still at 100% but using the backup power of 2 lithium 2032 cells. The third push turns the light off. I don't like that you have to cycle through the lithium backup batteries to turn the light off. I may take out the backups if I use the light a lot. The disposable lithium batteries are at least replaceable and offer more runtime when needed as well as better shelf life for storage. The lithium battery compartment is O-ring sealed so I'm pretty sure the light is at least dunkable. The solar batteries were precharged and ready to use out of the package, though the light was brighter using the lithium batteries. The head is sealed and the solar batteries can't be seen without destroying the light which I'm not willing to do. The sealed head would make modding difficult. I don't know what it uses for solar batteries, but I am hoping it's some kind of LSD batteries since it claims they hold a charge for 3 years. For about $11.50 per light, I think it's worth the cost. It's much brighter than a Nightstar Shake light. It's not as bright as a Freeplay Sherpa, but it's more waterproof. It's one of the lightest alternative energy flashlights I've seen. It doesn't have a fisheye lens that is too common with shake lights and other solar lights. They're also cheaper than most of the alternatives and you don't have to shake or crank it. Even if the solar batteries go dead, you still have backup power. The light's website is at http://www.hybridlite.com/Default.asp?Redirected=Y.
Sorry I didn't post this in the reviews section, but for some unknown reason, I wasn't allowed too. I tried.
