GrAndAG
Recently I've made some tests of my Ultrafire chargers and just wanted to share some results...
UltraFire WF-138
Test results (Li-Ion 3.6V)
- averaged by 10 sec
- without averaging (click to enlarge)
The charging was started at 260mA current, which decreased slightly and almost constantly during the process to 180mA at the end. The charging voltage was 4.35V at the end of charging. When the charging was finished there was no charging current (0mA, no tickle charging), the battery voltage was 4.26V (after 0.5 sec), after 30 min - 4.20V.
It seems the charger uses CC method only, but the its power supplier is a bit weak to provide proper power.
Test results (LiFePO4 3.0V)
The charging was made by 320mA current during almost whole process, and only at the last 3 minutes there was a slight decrease to 250mA with rapid increase in voltage (to 4.0V) simultaneously. Battery voltage was 3.80V just after the charging, and decreased to 3.40V after 3 minutes.
UltraFire WF-139
Note: I have the new generation charger, the 5V open circuit.
Test results:
- zoom on transition phase (click to enlarge)
The specs clam that the charging current is 450mA, but the actual charging was made at 360mA. When 4.15V was reached the current started decrease slightly, which should be supposed to be the CV stage. But the weird things happened here - the charging current dropped to 220mA, continued decreasing during following 70 seconds to 170mA, after that the charging almost stopped. After 10 seconds the charger "woke up" and increased the current back. the rest time it tried to work in CV mode, but without a huge success. The maximum charging voltage was 4.25V (260mA) at the end, after that the charging stopped. When the charging was finished there was no charging current (0mA, no tickle charging), the battery voltage was 4.16V (after 0.5 sec), after 10 min - 4.14V.
Addendum: After an hour I decided to continue charging of that battery by switching off/on the charger. The charging recommenced. The charger easily exceeded the previous stop limit and continued to feed the battery. During the next hour it additional added 250mAh to the battery. Why did it stop the charging earlier before? I have no idea.
But! After that hour, when the charging voltage was 4.35V (@200mA), the interesting thing happened - the voltage started jumping from 4.35V to 4.9V and back! I suppose it was the result of battery protection PCB work. But the charger ignored that event and continued to charge. After 25 minutes I decided to abort the experiment, because it seemed the charger wont stop. The battery voltage showed 4.28V after the experiment and did not decrease after 10 minutes.
The charts:
- "overcharging" (click to enlarge)
- magnified (click to enlarge)
P.S. Sorry for my ugly English.
UltraFire WF-138
UltraFire WF-139
Test results:
The charts:
