Frank88
I need your help for some parts of this project. I was browsing Ebay few weeks ago and found a 20 watt led. Well I bought it… It's a Led array, made of 5 lines of 4 led in series (1 watt each I guess) it's rated 13.8-16 Volts. I Thought I could make a Spotlight for my quad handlebars (KFX 450r '08) or make a flashlight out of it(im nort sure yet). When it arrived, I tried it with a car battery for few second just to see and OMG !!! that thing is nasty for the eyes ! and produce quite a lot of heat so for my project I ordered a 40x40mm heatsink (for motherboards) and a 40mm fan and once received, put it all together and made some test to see if it was sucking enough heat to prevent the led from burning, I checked the led with my welding helmet to see any change of light over time, well it's a success, after 5 minutes of continuous power, cut down the power and touched everywhere… COLD so its prefect in term of heatsinking.
But the light itself is floody, too much floody (but powerfull !) so now im searching for a suited reflector but found nothing on DX or ebay that could be used. Im searching for something not too much expensive and that would produce a narrower beam that could be more usefull for driving (around 45 degrees ?)
The Led is rated 1000-1500 lumens and stated Foward voltage is 15-18 V right now but when I bought mine I remember seeing 13.8 - 18 V and like said before works fine on my old car battery sitting at around 13.3 volts
The total size of the led is 40x32 mm and the led array(yellow) is 15x8mm
Note : I asked seller about hotlinking his image and it's okay, not asked for the others, removed
The only option I see right now is using a old Garrity 6Volt spotlight
Any idea, input or anything ? lovecpf
