You know gunga, that's a really good question that I've been wondering about myself. I've tried to dig around a bit and found some useful data. AW himself posted a discharge curve graph for his IMR16340 and LiFePO4s, but not his silver/black protected R123s. After some digging around I managed to find a few discharge graphs made by other CPF members on the performance of the black R123s and their results vary a bit so it may or may not be directly comparable with AW's own discharge curve graphs.
Here are links to different graphs:
IMR16340 (AW):
http://www.cpfmarketplace.com/mp/showpost.php?p=2214963&postcount=1
LiFePo4 (AW):
http://www.cpfmarketplace.com/mp/showpost.php?p=1503626&postcount=2
R123 (Silverfox):
https://www.candlepowerforums.com/posts/1398595&postcount=1
R123 (Raymond):
https://www.candlepowerforums.com/posts/2445971&postcount=1
R123 (GrAndAG):
https://www.candlepowerforums.com/posts/2640030&postcount=57
Here's a quick incomplete summary:
At
0.5A discharge, their capacities are as follows:
IMR16340: unknown
LiFePO4: 450mAh
black R123: 602mAh (Silverfox)
black R123: 570mAh (GrAndAG)
black R123: 557mAh (Raymond, avg of 2)
At
1.0A discharge, their capacities are as follows:
IMR16340: ~ 515mAh
LiFePO4: ~ 420mAh
black R123: 419mAh (Silverfox)
black R123: unknown (GrAndAG)
black R123: 481mAh (Raymond, avg of 2)
At
1.5A discharge, their capacities are as follows:
IMR16340: ~ 510mAh
LiFePO4: ~ 385mAh
black R123: 255mAh (Silverfox)
black R123: unknown (Raymond, avg of 2)
A note about Silverfox's graphs. His original post was made in May 2006 and last edited May 2007. AW released his black "high current" (max 1.5A discharge) R123 in Dec 2006, so I don't know if he tested the newer high current R123s or the older lower current R123s. The other thing is that his graphs cut-off at 2.5v, unlike Raymond & GrAndAG's graphs, both of which cut-off at 2.8V, so Silverfox's numbers actually a little higher than should be if you want to do a direct comparison.
The other thing about the graphs is that the LiFePO4s are on a differnt Y-axis scale because the starting and cut-off voltages are different from the IMR16340 and R123s (2.0V vs 2.8V), so I'm not certain if they are directly comparable.
So what does this all mean? At a 0.5A current draw, the R123>LiFePO4. I don't know where the IMR16340s fit in because there's no data for them at 0.5A draw. At 1.0A draw, the IMR>R123>LiFePO4. At 1.5A draw, IMR>LiFePO4>R123. This last bit is uncertain because I don't know which AW cell Silverfox tested and I can't find anyone else's graph testing the R123 at 1.5A.
What would be really useful is if AW produced a graph of the high current R123 so it would be more easily comparable. It would also be nice if he added 0.5A draw data for the IMR16340s too.
