21700 Flashlight with usb C charging and "Power bank" function?
Marquis07
B.C. Canada
Hey, does anyone know of any lights that charge with usb C, but can charge, say your phone, from the same C port on your light? I've looked around a bit and haven't found anything of the sort. Preferably, I would like it to function like a regular flashlight, say the Thrunite TT20, with an output of at least 1000 lumens. Also, if you know of any 18650 lights that are similar, I would be grateful.
Thanks,
Mark
turbodog
central time
Fenix made on that charges via usb-c but outputs as a power bank as plain usb. Takes 1-4 18650 cells. Max output varies depending on # cells present. Barrel is about like a small coke can.
I just got two of these Sofirn LT1 Minis for an upcoming camping trip. It charges a 21700 via a USB C port and can function as a power bank from the same port (according to the manufacturer’s site). I’ll try it out when I get home tonight.
Edit: not quite a “normal” flashlight format as it’s a lantern; technically one could remove the diffuser and use it as a mule, but then it wouldn’t be watertight.
Marquis07
B.C. Canada
@turbodog
Thanks, I've seen some like this before, but I'm hoping to edc the light, so the LR40R is a little big. Definitely a nice light though, maybe someday when I'm rich...
@scalpel_ninja
That's the type of charging I'm looking for. I looked at some of the other models Sofirn has, and they're built like conventional flashlights, but I think the Wurkkos TS21 would suit my needs better.
@timbo114
The Wurkkos TS21 seems like an awesome light! It's on a sale right now so I'll probably get it. The aundril 2 and magnetic tail cap are both major pros for me. Thanks a lot!
@DRW
I had forgotten about that one! I like it a lot, except it has no clip, and the battery is built in. Other than that, it seems like a solid light. Thanks!
turbodog
central time
Yeah, the 40r was large/heavy/HOT. It was too large and could be damaged under its own weight if dropped.
Marquis07
B.C. Canada
I watched a review on the Klarus G15 V2 recently, and it has a single in/out usb C port like the Wurkkos ts21.
