idleprocess
I'd like to see a side by side & top down photo of each battery, to understand their relative sizes.
Google Images delivers.
: all my cell purchases in almost 10 years now, have been unprotected :
Why is that?
My duration of use answers your question.
People who have used li-ions for a number of years, who buy quality products and who don't run series lights, don't really have a need for cell protection circuitry, which is ultimately a point of failure.
Chris
I'm just careful not to run the light after it gives a low voltage warning (in case the cells aren't perfectly matched).
I have some protected cells, and I'm generally unimpressed with them. IMO, the circuitry just adds resistance, and serves very little practical purpose. They're double the price, too.
Get lights with built-in low-voltage-protection, and you never have to worry.
I believe that 2.5V open-circuit is considered the threshold for a li-ion that should absolutely be disposed of with <3.0V considered troublesome. I generally cycle mine into the charger around 3.6V since operating voltage at that point under any significant load will be considerably less.Well, I've never had any, so I have no idea about what the threshold is for running lights when battery is low, or at what point it would be considered too low & end up doing damage to the battery
There is no such thing as a cell with built-in low voltage protection - that is the function of a protection circuit.So what is the difference between protected cells & cells that don't have that but do have built in low voltage protection?
So a series light with low voltage protection in its circuitry will prevent a good battery from being ruined if the other battery fails with high resistance? And it will prevent the good battery from pushing voltage into the bad battery and heating it up and perhaps a catastrophic exothermal reaction?
It depends on the cell, but 2.5v is a good ballpark if you don't know otherwise.
But, for example, the spec sheet for the Samsung 30Q states that they can be recharged (slowly) even as low as 1.0v. So, read the spec sheet if you want specific safety tolerances.
I've also seen test reports that claim you can even recharge cells that have slight negative voltage (i.e., reverse-charged to below 0v). I certainly wouldn't recommend that, though!
The upcoming FourSevens 26650 flashlight looks pretty neat.
Sounds like those 46800 cells would be the bees knees for larger lights. I'd love a modern take on a 2D mag. Maybe a bigger head though.
