22 Beamshots, my big lights (MC-E/P7/throwers/aspherical/HID)
HKJ
Copenhagen, Denmark
[size=+3]22 Beamshots September 2009[/size]
These lights are rather bulky and I had to split them over two pictures. The last light in the first picture and the first light in the second picture are about the same length.
On the first picture (Same sequence as on picture): DereeLight DBS XR-E R2, DereeLight DBS MC-E, DereeLight CL1H, DereeLight aspherical, JetBeam RRT-1 Raptor, JetBeam RRT-2 Raptor, Tiablo A10, Fenix TK11, Fenix TK20, Fenix TK40, Epsilon ED-P71 and Epsilon ED-P72.
Second picture (Same sequence as on picture): SolarForce L950m, Lunapower MVP, JetBeam M1X, EagleTac M2C4, OLight M30 Triton, Neofab Legion II, OMG Lumens DEFT, MicroFire Warrior, Titanium L35 and in the front a incandescent Maglite 6D.
The first graph shows all lights at maximum brightness and the HID lights are of course the brightest lights, followed by MC-E, P7 and triple LED lights, with the single led lights at the bottom. The big incandescent Mag is about the same as a single led.
Combining all the brightness settings in one graph, show the range the lights can handle and also how the brightness steps are selected for each light. The Legion II has 5 steps, but only covers a small brightness range, where M30 with 3 steps covers a much wider range.
These two graphs show brightness (lux) at 4 meters distance, again the HID wins, but the aspherical are not the weakest lights in this discipline even though they are single leds. Next comes the throwers and just below the throwers are the most focused P7 and MC-E lights. But as can be seen from the pictures below, great throw with low total light output, has its price, only a small area is illuminated.
[size=+1]Maximal Brightness[/size]
DereeLight DBS XR-E R2, DereeLight DBS MC-E, DereeLight CL1H:
DereeLight aspherical, JetBeam RRT-1 Raptor, JetBeam RRT-2 Raptor:
Tiablo A10, Fenix TK11, Fenix TK20:
Fenix TK40, Epsilon ED-P71, Epsilon ED-P72:
SolarForce L950m, Lunapower MVP, JetBeam M1X:
EagleTac M2C4, OLight M30 Triton, Neofab Legion II:
OMG Lumens DEFT, Maglite 6D, MicroFire Warrior:
Titanium L35:
[size=+1]Maximal Brightness, width reduces exposure[/size]
These pictures are a new series with 3 steps lower exposure, usual I only do 2 steps lower and uses the same pictures as above, but this time I wanted to get the HID's under control.
Titanium L35:
[size=+1]Maximal Brightness at a Longer Distance[/size]
Titanium L35:
[size=+1]Maximal Brightness, Long Distance[/size]
Some of the lights are not included, they do not work at this distance.
DereeLight DBS XR-E R2, DereeLight DBS MC-E:
Tiablo A10:
Titanium L35:
[size=+1]Minimal Brightness[/size]
I am missing the M1X, but the low setting would not be possible to see on the picture amyway.
SolarForce L950m, Lunapower MVP:
Titanium L35:
[size=+1]DereeLight DBS XR-E R2[/size]
The light is equipped with OP reflector and 3SD Q3 led module, this is not the best combination for throw, it is possible to order it with a smooth reflector and a R2 module for more throw.
The light uses 1x18650 battery and has 3 levels that can be stepped between with a fast off/on sequence.
Low, medium, high:
Medium and long distance:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]DereeLight DBS MC-E[/size]
This light has OP reflector and the 3SM MC-E 2.1A led module. It uses 2x16340 batteries, but it is possible to buy an extender for wider battery selection. It has 3 levels that can be stepped between with a fast off/on sequence.
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]DereeLight CL1H[/size]
The light is equipped with OP reflector and 3SD Q3 led module, it is possible to order it with a smooth reflector and other led modules. The light uses 1x18650 battery and has 3 levels that can be stepped between with a fast off/on sequence.
Low, medium, high:
Medium distance:
Low:
Medium:
High:
Medium distance:
[size=+1]DereeLight aspherical[/size]
The light has the 1SD R2 led module, this is the brightest led module from DereeLight (until R3 or R4 arrives), a MC-E module will give less throw. The 1SD is a single level module and the light uses 1x18650 battery.
Medium distance:
Long distance:
[size=+1]JetBeam RRT-1 Raptor[/size]
This light uses 1x18650 or 2xCR123 batteries and the brightness is changed with a ring.
Read my Danish review here: JetBeam RRT-1 Raptor
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]JetBeam RRT-2 Raptor[/size]
Read my Danish review here: JetBeam RRT-2 Raptor
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]Tiablo A10[/size]
This light uses 1x18650 or 2xCR123 batteries, I am using a single level tailcap on mine.
Medium distance:
Long distance:
[size=+1]Fenix TK11[/size]
The lights uses 1x18650 or 2xCR123 batteries, the brightness depends on if the head are tight or loose.
Low, High:
Medium distance:
Low:
High:
Medium distance:
[size=+1]Fenix TK20[/size]
The lights uses 2xAA batteries, the brightness depends on if the head are tight or loose.
Low, High:
Medium distance:
Low:
High:
Medium distance:
[size=+1]Fenix TK40[/size]
The light uses 8xAA batteries, brightness is changed by holding the button down, a double tab on the button will select one of the flashing modes.
Read my Danish review here: Fenix TK40
Low, medium, high:
Turbo:
Low:
Medium:
High:
Turbo:
Medium distance:
Long distance:
[size=+1]Epsilon ED-P71[/size]
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]Epsilon ED-P72[/size]
The light uses 2x18650 battery and has 3 levels that can be stepped between with a fast off/on sequence.
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]SolarForce L950m[/size]
The light uses 2x18650 battery and has 2 levels that can be stepped between with a fast off/on sequence.
Low, High:
Low:
High:
Medium distance:
Long distance:
[size=+1]Lunapower MVP[/size]
The light uses 2x18650 batteries and has 3 levels that can be selected with the side switch, the tail switch is used for on/off.
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]JetBeam M1X[/size]
The light uses 2x18500, 2x18650, 3xCR123 or 4xCR123 batteries. With tight head max. brightness is selected, with loose head it is possible to program the brightness with off/on presses. My version is 1 generation, the current version is supposed to be a bit brighter.
High:
High:
Medium distance:
Long distance:
[size=+1]EagleTac M2C4[/size]
The light uses 2x18650 or 4xCR123 batteries, the brightness and on/off is controlled with a ring on the light. My version is 1 generation, the current version is supposed to be a bit brighter.
Low, medium, high:
Turbo:
Low:
Medium:
High:
Turbo:
Medium distance:
Long distance:
[size=+1]OLight M30 Triton[/size]
The light uses 2x18500, 2x18650, 3xCR123 or 4xCR123, I uses 2x18500, the brightness is controlled with the button on the side of the tailcap, on/off with the switch at the tail.
Read my Danish review here: OLight M30 Triton
Low, medium, high:
Low:
Medium:
High:
Medium distance:
Long distance:
[size=+1]Neofab Legion II[/size]
The light uses 3x18650 batteries and is controlled with a ring that must be turned momentary to the left or right to select brightness, on/off or battery meter.
Low, #2 #3:
#4, High:
Low:
#2:
#3:
#4:
High:
Medium distance:
Long distance:
[size=+1]OMG Lumens DEFT[/size]
The light uses 3xAA batteries, but they must be rather slim. In my test here I am using a XR-E R2 led, extra colliminator lens and the clear aspherical lens, this setup can be changed. What setup is possible will depend on what generation of the light it is.
Medium distance:
Long distance:
[size=+1]Maglite 6D[/size]
The light uses 6xD batteries, this gives a long runtime with declining output and makes the light heavy.
Medium distance:
Long distance:
[size=+1]MicroFire Warrior[/size]
The light has a build in LiIon battery and a charger is supplied with the light.
Medium distance:
Long distance:
[size=+1]Titanium L35[/size]
The light has a build in LiIon battery and a charger is supplied with the light. The handle has a small led light build in, that can be used independent of the main HID spot.
High:
High:
Medium distance:
Long distance:
[size=+1]Notes[/size]
As usual the pictures are with daylight white balance, even though the EXIF information says auto.
WOW!!! Talk about beamshot overload!!
:twothumbs :thumbsup: :thumbsup: :grin2: :thumbsup: :thumbsup: :twothumbs
Thanks for posting these HKJ-there's a lot to digest.
One thing you might consider in the future-some of us find beam shots in an open field with a grove of trees somewhere around 100yds. away very useful.
The field CPF member Wattnot uses in his reviews is my idea of a perfect field.
Again thanks for posting.I can't even begin to imagine the amount of work you put into this.:thumbsup::twothumbs:thumbsup::twothumbs
Wow!! This is HUGE!! Thank you for the time and effort that went into this, it's awesome!!! What an incredible collection of lights, too!
Wow. Just . . . wow. Thanks so much for all the work. I hate to nitpick, but you say the Dereelight DBS with the aspherical is the brightest. I'd say the MC-E is the brightest but the aspherical focuses the beam much more tightly and gets the light out farther.
Like I said, I hate to nitpick someone who can get off their a$$ and get all these beamshots, not to mention all the post work to load the pics and organize them so efficiently, but Dereelight is my light of choice, at least amongst throwers and I go for a common lexicon so that it's easy to talk about performance between different brands and models.
Again, thanks! :candle::twothumbs
I do not thing I say that, I say that the R2 led module is the brightest led module and this is because it has the highest surface brightness.
I associate brightness with lux, not lumen, but I am not always consistent in my writings.
Another great awesome post! :thumbsup::twothumbs Thanks for all your hardwork and the information you've put in. Great excellent job in organizing all the beamshots for these lights. :twothumbs:party:
Terrific. Exactly what I needed to decide on a new thrower. HKJ, thanks for the excellent work!
how far is the long distance shot?
This and what is the distance of all 3 shots.. close medium and far. OUTSTANDING write up none the less. Think you just talked me into the L35... thanks.
Incredible shootout, HKJ. I have always wondered about how some of those lights compared in throw (L35, MicroFire Warrior, DEFT), and now I have the answers because of your excellent pictures. I am amazed at what a significant amount the L35 appears to exceed the MicroFire Warrior in throw by.
Thank you for all of the effort you went to for this review, it is spectacular.
Wow Indeed. Nice review and collections. I wish i am as lucky as you are lovecpf
