Hi supasizefries. I usually wait at least 30 min. before I run the light. FYI, I would say to run this bulb in direct drive mode, without something like a PWM switch, the voltage should not be over 16.5V. (See LuxLuthor's testing thread:
https://www.candlepowerforums.com/threads/179748) His testing shows the bulb blew at 16.9V.
I just went and tested the battery pack voltage a few minutes ago and it was 15.5, after about 1 or 2 minutes of runtime and last charged some 3 or 4 days ago. After charging it can get up to about 16.8 or so, so I have been waiting until it drops. Just use my multimeter to measure the voltage.
Another note is that when I first starting using this light several years ago, I had not been aware of (and I think it was not even out yet...) Lux's testing. I was relying on various posts by the numerous hotwire champions around these forums and info from the now-disgraced-forever AWR. Since the bulb is a 2000 hour bulb, it can take quite a bit of initial voltage. I sure would not try direct drive on a bulb like the 62138. LuxLuthor's tests show it blowing at 15.0V.
Hope all this helps!
Regards.
