Found another cheap single AA light @ Ocean State Job Lot. Ouput was pathetic of course, but it provided a nice host for an AA powered XPG using a Shiningbeam 1A boost driver.
Original AA light
340 mA off 1 AA
Output ~ 10 lux by ceiling bounce
Tint = bluish :sick2:
Exploded view
Emitter and boost driver
Current draw from AA
Now, let's give this thing some muscle....
Deanodized body
New grippy
XPG neutral white emitter
Shiningbeam 1A 3-speed driver
Custom copper heatsink
Tailcap "button" (not clicky)
Stock reflector was ground slighty to focus the XPG.
Exploded view
Driver pill
Stock driver (left). Shiningbeam driver (right)
Current draw on low, medium and high running off 1AA Duraloop. On/off is by twisting head. Mode changed by slightly depressing tailcap button. Very smooth and easy mode changing which works flawlessly. I measured 350 lux on high by ceiling bounce. The body does get warm pretty fast on high which is a good indication of heat transfer. Definitely not something that could be run for extended periods on high, but then again, no light this size can provide sufficient heatsinking at that output. On low, it can be run for quite a while without heat issues.
Side-by-side. Stock AA (green). XPG modded (raw)
Beam shot ~1 foot from wall
And across the room ~15 ft. I don't think my doggie was very happy to be blinded
Of course this is not Fenix quality, but for an initial $3.88 investment for the host and ~$12 in parts, plus what I had lying around, I think it turned out pretty nice. Sure looks a lot better than the original, not to mention the increased output and multi-mode options.
Original AA light
340 mA off 1 AA
Exploded view
Deanodized body
New grippy
Exploded view
Driver pill
