Looking to build a 2c rop le, this will be my first mag mod. I have seen so many different options not sure which way to go, Lots of mention of FM reflectors,are they still available? if not what to use now, KD?. any and all sugestions apreciated.
That's what I was looking at, or a wa1111, where can i get a fm reflector? should i go with a smo or lop (trying for max throw)?
Thanks for the advice, what about the kd aluminum reflectors?
Where can I get most of the parts? Lighthound? and how do I contact Fivemega?
I imagine runtimes with a ROP high are in the 1/2 hr range, what about the WA1111? any info?
I disagree with this -- I'd say get the 8.4mm, and IF you don't like it, cut out the flat portion. However, if you find you don't mind it, those are free lumens you are getting that would otherwise disappear down the hole in the back of the reflector, if you were to buy one with a large opening.If you do go with a KD reflector, do not get the 8.4mm opening reflector. The beam looks horrible. Get the other one with the stock size opening. I actually bought the 8.4mm one and ended up taking my knife and carving the flat spot out to fix the beam.
How can you use the ROP bulb with the 8.4mm opening reflector? :thinking: The socket will definitely interfere with the reflector as it rides the cam.I disagree with this -- I'd say get the 8.4mm, and IF you don't like it, cut out the flat portion. However, if you find you don't mind it, those are free lumens you are getting that would otherwise disappear down the hole in the back of the reflector, if you were to buy one with a large opening.
For some beamshot comaprisons, including between the FM MOP, Kai MOP, and Kai SMO, check out the link in my sig. I personally don't mind the beam artifacts, particularly not when looking at targets several hundred meters away![]()
The ROP bulb itself fits through. The cam is the same dimension as the stock cam however, and causes the bulb itself to withdraw from the reflecotr, so there is never a "collision". I actually custom ground one to have a gentler slope so that the bulb wouldn't withdraw too far, and I would actually have an optimum range of focus on the ROP lamp.How can you use the ROP bulb with the 8.4mm opening reflector? :thinking: The socket will definitely interfere with the reflector as it rides the cam.
Checked out your thread but the photos seemed to be missingFor some beamshot comaprisons, including between the FM MOP, Kai MOP, and Kai SMO, check out the link in my sig. I personally don't mind the beam artifacts, particularly not when looking at targets several hundred meters away![]()
I tried my 8.4mm opening reflector and to my surprise it worked. I'm not sure I really see any difference in the beam though when it's focused down. :thinking:The ROP bulb itself fits through. The cam is the same dimension as the stock cam however, and causes the bulb itself to withdraw from the reflector, so there is never a "collision".
Ok, well I checked again and compared my two ROP's (one with 8.4mm opening the other with the 15mm). The 15mm one will focus down to a spot better than the 8.4mm one at least at close range 6 & 20'. I'm not sure if the same effect will occur on a more distant target though.I'm not sure I really see any difference in the beam though when it's focused down. :thinking:
