32650 D36 & 8AA D36 (2)
fivemega
California
(AVAILABLE)
Please allow 7 days to ship​
Left: 8 Serial NiMH 9.6 Volt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Right: 4 Serial NiZn (6.4 Volt)
Or 4 Eneloop (4.8 Volt)
Please read completely before you post or buy then pay and post.
Absolutely NO reservation.
Hi folks, Here is another new toy for you.
These bodies are similar to these but takes D36 and come with bezel and Borofloat lens. D36 module and battery/battery holder are (NOT INCLUDED).
Bodies have larger ID to accomodate 32mm cell.
Short version will work with single 32700, 32650, single 26650 with sleeve or 4AA rechargeable. (battery holder not included)
Maximum battery diameter of 35mm and length of 74mm will fit in short size version.
Long version will work with 8AA.
Maximum battery diameter of 35mm and length of 128mm will fit in long size version.
Please note that using NiMH will give you different voltage than NiZn and make sure lamp module is capable of that voltage.
All bodies, tail caps and bezels are black hard anodized and no other color is available.
First picture shows short and long version and second picture shows short version with loaded 4AA battery holder (NOT INCLUDED).
Tail cap has more attractive milling similar to M6 and can accept either version B of these or McClicky.
Switch boot is easy to operate with one hand and choice of black, orange or green GID
Head and body are machined from one piece of high grade aluminum bar and has lots of fine and deep grooves to manage better heat dissipation which is more critical with extreme hot LEDs such as SST-50, SST-90, multiple XML or extreme hot WA1164
Will take many different D36 lamp assemblies such as this, this, FM-D36 socket/reflector module or any other drop in D36 lamp/LED modules.
I strongly suggest these for single 32700, 32650,26650 or FM-D36 socket/reflector+WA1164 module (1500 Lumens) for 8NiMH.
It is possible to use 4S/2P battery holder (4.8V, 4000mAh) if your module can take this voltage.
Also possible to use with higher voltage NiZN rechargeable but your module must be capable to work with this voltage
D26 bodies are available here.
Possibilities are endless.
I use STT-90 drop in with 1x32650 and never seen such a light and such a long run from this small package. Thanks Dave. 👍
Advantages:
Not only you will get long run time compare to 17mm or 18mm cells but brighter output because of less voltage sag, less stress to cells and less frequent recharge. Not to mention there are lots of voltage and power possibilities.
Body thickness is about 42mm which is about 2mm fatter than original M*g D but tail cap has 45mm diameter, so chance of slipping out of hand is very little.
Each body comes with one head o'ring, two tail side O'rings, one tail cap, one dust cover boot, one crenelated bezel, Borofloat lens and lens O'ring. No lamp assembly, and No batteries or battery holder included. McClicky switch is optional for additional of $14 installed or insert and tighten your switch inside tail cap.
What you get is a complete host including body, tail cap, tail cap boot, bezel, lens and all needed o'rings. McClickie switch is not included but optional. Head and body is made of one piece (nonremoveable) high grade aluminum with lots of deep fins for better heat sinking.
*These bodies are designed to take several different types of D36 modules but you may need to extract short spring of some modules.*
Price:
Black 1x32650 $89 (AVAILABLE)
Black 8AA $99 (AVAILABLE)
4 serial white battery holder (4.8 Volt) $38 (AVAILABLE WITH PURCHASE OF BODY)
8 serial white battery holder (9.6 Volt) $40 (AVAILABLE WITH PURCHASE OF BODY)
4S/2P black battery holder (4.8 Volt) $40 (AVAILABLE WITH PURCHASE OF BODY)
HOTWIRE D36 socket/reflector without bulb $40 (AVAILABLE)
McClickie switch (with switch ring) $14 installed (AVAILABLE)with purchase of body.
Extra boot (switch cover) $1 (AVAILABLE) with purchase of body. (Black, orange or GID)
Shipping to States $6
Internationaly $16
Please add 4% to total for CC paypal fee.
Insurance $2.60 for each $100 value in States
Insurance $6.75 for each $100 value internationally
I am not responsible for loss or damage once I ship your package.
NO battery available or will be available.
No reservation please. You must pay FIRST then claim your spot by posting here. I will sign your name right after receiving payment unless you paying by MO.
Please don't pay if you may change your mind. There will not be any refund.
It is ABSOLUTELY NECESSARY to pick next available and valid number, post detail of your order here and paypal note along with your CPF handle.
I will never figure out what for is your payment and from whom without above information therefore I will reject payment.
Example:
Mr Genefire :paypal: for #65 1x32650 with black boot
Paypal: [email protected]
Please PM for postal money order payment.
Any comment welcome.
Will ship by:
www.USPS.com
#01 1x32650 D36 $89 stoli67 paid shipped
#02 1x32650 D36 $89 EvilLithiumMan paid shipped
#03 1x32650 D36 $89 rcantor paid shipped
#04 1x32650 D36 $89 rcantor paid shipped
#05 1x32650 D36 $89 tadesko paid shipped
#06 1x32650 D36 $89 (SOLD)
#07 1x32650 D36 $89 (SOLD)
#08 1x32650 D36 $89 (SOLD)
#09 1x32650 D36 $89 (SOLD)
#10 1x32650 D36 $89 (SOLD)
#11 1x32650 D36 $89 (SOLD)
#12 1x32650 D36 $89 (SOLD)
#14 1x32650 D36 $89 (SOLD)
#15 1x32650 D36 $89 VanIsleDSM‎ paid shipped LC548066818US
#16 1x32650 D36 $89 teach9213 paid shipped LC548063754US
#17 1x32650 D36 $89 xml paid shipped 03110240000019938676
#18 1x32650 D36 $89 TB paid shipped 03110240000019938652
#19 1x32650 D36 $89 donn paid shipped 23082940000001845989
#20 1x32650 D36 $89 quazimoda 2 paid shipped 9505510518353220436380
#21 1x32650 D36 $89 pinkpanda3310 paid shipped LC550834417US
#22 1x32650 D36 $89 yellow paid shipped LC550834505US
#23 1x32650 D36 $89 (AVAILABLE)
#24 1x32650 D36 $89 (AVAILABLE)
#25 1x32650 D36 $89 (AVAILABLE)
#26 1x32650 D36 $89 (AVAILABLE)
#27 1x32650 D36 $89 (AVAILABLE)
#28 1x32650 D36 $89 (AVAILABLE)
#29 1x32650 D36 $89 (AVAILABLE)
#30 1x32650 D36 $89 (AVAILABLE)
#01 8AA D36 $99 rcantor paid shipped
#02 8AA D36 $99 (SOLD)
#03 8AA D36 $99 (SOLD)
#04 8AA D36 $99 ErikP paid shipped 9505511144965134525188
#05 8AA D36 $99 (AVAILABLE)
#06 8AA D36 $99 (AVAILABLE)
#07 8AA D36 $99 (AVAILABLE)
Question?
Please see post #32
(A V A I L A B L E)
Question?
Hi, I'm really interested in the 8AA version.
Do you know where I could source one of these:
Do you mean 8AA to power up WA1164 ?
If so, reflector/socket is available in post #1 of this thread and battery holder is available
here.
Same reflector/socket with WA1111 can be used with these 2x18650 bodies.
Fivemega, do you think (4) 14500's would fit in your adapter? They measure out at 52mm long.
Yes,
4 AW's protected 14500 will fit in 4AA adapter and inside barrel of above 4AA body with total nominal voltage of 14.8 volt.
What are the lengths of both lights (from bezel including tailcap)? Interested, but now have to decide in which one .
The 3x 17670 adapter does not fit in the 8x AA host i presume? Widthwise I mean?
Short one (1x32650) is about 160mm and longer one (8AA) is about 210mm including switch boot.
A loaded
3x17670 battery holder will not fit.
Please advise which way should I put in the battery holder? A or B (which side is positive of the holder)?
Charging port is at tail side.
Black plastic pressed in knured brass nut is Positive and at module side.
Make sure brass plug is inserted in charging port.
I'm confused between the two four-cell battery holders. Both are shown as 4.8v, I assume with 4 Eneloops. What is the difference?
You may want to check here.
Assuming each Eneloop is 1.2 Volt, 2000mAh
White 4AA holder will give you 4.8 Volt @ 2000mAh (4 serial)
Black 8AA holder will give you 4.8 Volt @4000mAh (4 serial / 2 parallel)
White 8AA holder will give you 9.6 Volt @ 2000mAh (8 serial)
So there is only one type of 4 cell battery holder.
FM, is the d36 G4 socket and reflector combination available for purchase without the light itself? Thanks!
Yes, you can purchase D36 socket/reflector without flashlight.
Will your 32650 D36 host fit a 34mm diameter by 610mm length battery?
Also, will your 8AA D36 fit a 32mm diameter by 113mm length battery?
