4-1/2" C-Flex Flame Thrower!!!
TnC_Products
Arizona
I don't want to give away too much information about this prototype project I have been working on. I have been wanting to build a head like this for a while just never had the chance to get one finished. Well, I have finally finished a prototype that fits onto the C-Flex battery tubes. My prototype is direct drive (my preference), but they can be made with a 5 mode converter also. Hi-Med-Low-Strobe-SOS. I know people don't really care much for the strobe or SOS but that is how it was programmed. If I could get one programmed that is just three modes I will. Since this is in a prototype stage I might have a ilttle time to do that.
Some specs:
length - 4-1/2" long
Tube Dia - 1-1/4 dia with slightly raised Knurling
Head Dia - 1.990 dia with thin crenulated bezel.
Module is screwed into the head from the front (lens side)
Produces a min of 600 lumens on a single Li-ion C-size battery
Creates plenty of flood with a nice tight hot spot beam (20mm reflector')
Much tighter hot spot than a P7 or MC-E with a 27mm Reflector
Since it throws farther is seems much brighter than a P7 or MC-E (actual output has not been tested, just visual)
These will probably be Hard Anodized Black or EN Plated. Still undecided.
I will attach some pictures for you guys later today when I get home. I will also include some Beam Shots showing the Difference comparted to an MC-E & P7.
Hope there is enough interest in this to do a small run of these lights. Compared to the lights I have here this thing is amazing.
Pictures coming soon!:poke:
Added a few more pics to the first post. I will get some P7 shots as soon as I get a chance.
I can`t see any pics.....:thinking:
I know Eric had some troubles a while ago posting pictures aswell,
I want to see pictuuuures.........;)
No pics for me too. :shrug:
I'm interested in heads for my C-flex bodies. I don't know if I'll need another body for the fact that I own about 5 or 6 bare aluminum units. A complete anodized package might work for me though.
T
I`d realy like a C-body/clicky/biga##head sporting a P7....
Excuse my lingo......:thumbsup:
Pics are up! Thanks Chris!
Did you mention the reflector that you're using in the proto head?
T
This is not too bad of an Idea. But I think it is even something better. :ironic: I might reveal the front view tomorrow. But as you know it uses only a 20mm reflector.
:poke: Could this be a tri-cree XR-E using McR20 reflectors? :thinking:
I was going to guess one of the 1000lm Ostars, but that hot spot looks too well defined, and running that well off a single Li-ion (even a "C") would require an interesting driver. Maybe a Tri-FluPIC and a tri-Rebel Endor Star?
The 27mm head looks great on the C-Flex body!
Ok. here are the pictures of the head!
If it uses only one 20mm reflector why are you then using a 2" head? :thinking:
:poke: Tri-Flupic, one McR20 and two aspheric lenses then? :whistle:
Damn you... :whoopin: :nana:
What emitters are in it? :goodjob:
:thinking: Must be K2's? lovecpf
