I am building a C-cell mag with 2x AW "C" cells.
I plan to use four SSC emitters, but that is not set in stone. I could be persuaded to use three or maybe switch to Crees depending on ease of fitment into maglite head.
This is what I've figured out so far, tell me if it is correct:
Two Li-ion cells put out 8.4v fully charged and ~7.2 at cutoff.
SSC U-bin has a Vf of 3 to 3.25v
...so four SSC emitters have a Vf of of 12 to 13v.
Since my cells put out 8.4v at most, and I need at least 12v to power the emitters, I need a driver that increases voltage.
Here is where I need the help. I'm totally clueless when it comes to what circuitry I need. I've heard terms thrown around like "shark" and "downboy" and the like, but I'm more or less clueless. I would like multiple modes, but I don't have a preference as to the power output or number of modes. I would like the maximum mode to run each emitter at or about 1a. It would be awesome if I could drill and tap the body to install some kind of position switch or rheostat instead of having to use the stock switch to change modes. However, if it's cheaper, or lots less trouble, I will stick with the stock switch. Somebody please point me in the right direction.
Also, what would be the best heatsink for four SSCs into a C head? Also, after looking at other builds, it seems that 19mm or 20mm a good size for each reflector -- what are my options?
I have fine soldering skills, so I am confident that if somebody explains it to me I can do it. Thanks in advance.
copperfox
copperfox
