4sevens
Re: 4Sevens Preon ReVO Review with OTF Lumens and 140 minute runtime
1) Firstly the P1's lumen rating was grossly inflated. It was not even "bulb lumens," it was calculated/theoretical lumens. Q123 is actual OTF (out the front)
2) The Q123 has a much more sophisticated circuit. Not only does it fully support li-ion's with a wide voltage range of 0.9-4.2v through two separate drivers (buck and boost). Also, the Q123 has a MCU (microprocessor) that controls the drivers to put out different levels. The P1 is simply a boost circuit and use of li-ions are at your own risk (and to the risk of the LED since it's direct drive).
P1 vs Q123 is an apples to oranges comparison.I would say efficiency has improved quite alot. A small single AAA light matching closely against a CR123 light is pretty damn good.
Try comparing the P1 with another CR123 light, like the 4Sevens Quark123. About double the runtime at 85 lumens.
