Once again through the very kind courtesy of 4Sevens I have these 3 Quark 123-2 (2x CR123) lights to compare - the Neutral White, regular Cool White and Tactical versions.
Size -
not much to see here.....
externally there is little difference - the tactical version has the protruding tail-switch boot (which makes it not able to tail stand).
Heads -
hard to see any difference between the Quark heads - the Neutral White perhaps seems to show a little more brown in the reflector.
Comparison on Max all using primary CR123A -
Neutral White vs. regular Cool White -
the cool white looks pretty blue in comparison - but it is only slightly on the blue side - see later comparisons. By eye these seem about the same brightness - but obviously the very different tints makes the comparison difficult
So I removed the color by deSaturation -
with the color removed by desaturation - the regular cool white does seem a bit brighter.
Neutral White vs Tactical (regular Cool White)
again the Tactical cool white looks more blue because it is in direct comparison with a warmer Neutral white - but one can see that it is a little less blue than the regular cool white in the standard version - this is probably just variations in the bin.......
Tactical Cool White vs. Regular Cool White -
side-by-side one can see the tint difference - but in isolation this is all pretty trivial........
Neutral White vs. Fenix P3D-RB100
this Fenix P3D-RB100 has one of my favorite tints for a regular cool white -
In comparison with other (Cree) cool white the RB100 looks "warm" -
Quark 123-2 Cool White vs. Fenix P3D-RB100
the Quark looks a bit brighter - but the Fenix Rebel has a much nicer tint - the Quarks all have very nicely centered beams - the Fenix Rebel does well too.
Quark 123-2 Tactical vs. Fenix P3D-RB100
the tactical version seems to have a slightly better tint than the other Quark, however it is still not quite as nice as the Fenix Rebel, although it is close - again the Quark may be slightly brighter - the Fenix Rebel again matches the well centered beam of all Quarks.
The Tactical version differs from the regular version Quarks in that the Tacticals (obviously) have a forward/tactical clicky - it can have two memorized modes accessed by tightening loosening the head - each of the two accessible modes can be programmed from a choice of 8 modes -
I'll just attach the scan of that part of the manual here -
there is a slight typo/mistake - there ought to be an arrow between Max and SOS.
These Quarks all have common traits in very well centered - therefore nice smooth beams - they all have lots attention to detail and quality.
I personally like the Neutral white version - and although I have long been an advocate of the forward/tactical clicky - I am willing to forgo this very desirable feature for the easier accessibility of the all the brightness levels in the regular version - I like the the sequence of going from Moonlight > Low > Medium > High and the ability to get to Max by tightening the head - this feature was originated by Fenix - but 4Sevens' Quarks just have so much better and more useful levels.
Once again winner(s) from 4Sevens in this really nice Quark series.
INDEX to Follow Up Parts-
More comparisons with Neutral White Quark 123-2 - Post #8
Tint binning of NiteCore EZaaW and the Quark 123-2 - Post #10
Standardized Stairway Beamshots - Post #11
Comparison with with almost the opposite end of the scale the Quark AA Neutral White - Post #12
Size -
Heads -
