jzmtl
I know it's only a couple of years too late with the domination of LED, but maybe it'll help someone.
Received tec 40 yesterday, contact with rechargeables is problematic due to flat contact piece on bottom. Tried aluminum foil as suggested here but it gets crushed quick and tec 40 turns back into battery crusher.
Simple solution, something priceton tec should've done to begin with. Pull out the flat contact piece from bottom of the barrel with a dental pick tool/o-ring puller, it's glued on by a thin foam piece. Now take a nail and hammer, punch two holes where battery terminals would push against. Now find a small spring from a retractable ball point pen, cut about three loops off each end. Thread the spring through the holes with one loop below and two loops above, sand off any sharp point. Glue the piece back in, viola, perfect contact every time.
