Yes! That's even better than the volume knob model.
Also, 5 positions, 72 degrees apart? Do you work for the Pentagon? Are you a star? Gimme five! You devil...
5x72=360 math major in college.
4 levels and off
4 levels and off
4 levels and off
Oh, I know. Just couldn't resist: pentagon, star, pentagram (devil), etc.
I should be... Punished.
There you have it Guy, FlashFlood has volunteered to get the absolute very last Torpedo you ship. He can wait til everyone else gets one for being facetious.
Agreed. Flashdark mode is a prestigious tight closed group, only available by accidental invitation.Don't say that, it might invite the flashdark mode!
I guess I prefer shoveling gravel also. It usually is not 20 below(-28C) like it was last night.
GL
@tgwnn: something I forgot to mention: my precious (X024) doesn't seem to have the parasitic drain issue that other folks have mentioned. I'm using the short body with the new (black) MBI nuke 10250. After three days of light use, the battery is still at 4.12V. Just FYI, in case the lack of problem on this serial number tickles a neuron as to why others are affected and this one is not.
i've noticed this quirk twice. THe first time i swapped batteries and it didn't occur again until it wouldn't maintain the 2nd level and turned out to be down to 2.97v. The second time this occurred I took the battery out and checked it, 3.92v. decided I would check it a bit closer, put it back in and it is still working on level 3 and now it is down to 3.8 with a little more use but maintaining.I've noticed some more problems:
1. With 10250 batteries the light usually works on 3rd level only a fraction of second. It works consistently on 3rd level only with fully charged battery, and if the battery is 4.0V or lower, it won't work. Surprisingly, if you are fast enough to scroll to 4th (max) level, it will work for 30sec as it should.
Hi cnlson,one more thing i note. since the nukes are so darn bright i thought it would be fun to EDC it. so on my keychain when the keys are in the ignition, if the road is bumpy the light turns on low. happened 3 times tonight on the way back from Buffalo Wild Wings.
Hi Dale,Guy, that would be greatly appreciated if you can divert it to Texas. Let me know and I'll send you a PayPal.
Husker, if you're not going to use those Efest cells I'll gladly take em off your hands. Shoot me a PM and we'll work out the details. I keep finding more and more ways to use em.
Nice work on all the info Tribal Family. Very good reading and critically pertinent information, ready to give one a go my ownself. (wondering if I can fit an MT-G2 in there...)
Hi Cataract,The beauty of the propeller lockout is that you could also go instantly to off.
If I may get fancy with the propeller lockout idea (like anything has ever stopped me from doing so);
Quarter turn anti-clockwise (with a detent) = lockout, but with mode memory. In other words, when you turn the propeller to the right again, the light comes back on in the last mode it was. I know, very hard to achieve, but check out the REAL fancy part:
3/4 turn anti-clockwise, the propeller pops out 1/8" and becomes a momentary switch. you gotta want to kick me for giving you such tempting yet almost impossible to achieve ideas (like you didn't have enough of your own...) that would give the propeller 100% functionality! (plus, it's like a secret code or an easter egg!!!)
P.S.: I didn't send those flashdark codes... perhaps Uni did or the Unobtanium pill is spreading them through the tunnels, but there is also a possibility the interface funkiness is simulating the code... will definitely try to reproduce it backwards.
The metal parts on cars seem to have an inconvenient tendency to be somewhat magnetic... I never could use a compass inside my cars, perhaps your torp was turned on by proximity to the metal parts -or anti-theft hidden sensor - under the steering wheel while shifting around? Then again, it might just be MY cars that become magnetic from all those abductions...
Hi cnlson,aaaaand predictably today i could not get it to turn off without lining up the marks. randomly temperamental.
that being the case, although i'm not in favor of a lockout, perhaps it is needed. at least a parking position that cannot turn on (with a detent to be able to put it there by touch.)
i still think 5 postitions, 72 degrees apart, fixed with detents, rotate 1 way for high to low, the other for low to high would be a seriously nice UI. There are times I'd love to start on blindingly bright (what's that noise?) and others the dimmest available (grandkids camping/sleeping in the basement)
any thoughts on a keychain keeper for a spare nuke? although they are bright they seem to run down fairly quickly. something printable on the 3d printer perhaps? Keychain containment
Hi KD,With constant comment on Ti vs. other metals with better heat transfer, or Ti vs. other metals with less durability (and less beauty) it seems that this copper/titanium alloy could be the perfect answer.
I keep watching your threads, not commenting much because there's so much traffic it's hard to follow, but I'd also think that this alloy could avoid the heavy tarnish and smell issues that some have with copper.
When I first posted about it I half expected you to say you were already working with some and I don't see how you address every single reply here, hold a full time job and make these lights happen.
Thanks agt :thumbsup:Yes, I'd like to see this kind of UI too.
Hi mcbrat, sure could beThat would be slick.
flashflood,Yes! That's even better than the volume knob model.
I've been carrying my TorpedoX every day for a couple weeks. I've used it on the job a couple times, but due to the finicky UI, most of my use has been under more casual and less demanding circumstances. I've found that the UI has become slightly more predictable and consistent over time. Some of this is surely due to the fact that although it is finicky, I have picked up on some of its more predictable quirks. I've learned that operating the switch quickly will drive it crazy. If I wait a second before changing settings, it is much more reliable. Also, when it reverses its response to a switch operation, I can now oftentimes slow it down, reverse it again, and then it will settle down to responding properly again.
Here are additional observations in list form:
~ The rotational operation of the switch requires a greater twist for the lowest two positions than it does for the highest two.
~ The rotational operation of the switch is convenient and pleasurable. This design is definitely the best light mechanism I have experienced.
~ The packaging was impressive and I appreciated the attention to detail and polished impression it gave me.
~ One of the batteries remains stuck in the packaging.
~ the short body is offset concentrically from the head.
~ upon arrival, the nuke retained a charge of 3.8 volts.
~ the o-ring would roll out when I assembled the short body (I slowed the assembly process which alleviated the problem).
~ The output is very warm by my eye, much warmer than my HFR-UTT.
~ The output is perceptively less than my UTT, but some of this perception is surely due to the warmer tint.
~ The short body's length feels good in my hand when operating the switch. My first reaction was that I would prefer it to be shorter like my UTT, but after use, I've found this length to be more ergonomic for my hand.
~ I like the sharp tail fins as they make it easier for me to identify the front end without looking.
~ Battery drain during idle is quick. The nukes will go from ~4.15V to ~3.7V in 12 hours without use. It will continue to drain the battery after the auto step down has activated.
~ Battery rattle with eFest 10440.
~ I absolutely love the appearance and aesthetics.
This light is everything I expected for this beta level and I'm looking forward to the production model with a reliable UI. I would opt for a slightly cooler tint if possible. Even with the quirky UI and battery drain issues, it will be a pleasure to carry this light daily for the foreseeable future.
if anyone needed a small momentary only light, I think a Black Zoom head, black momentary switch, and either Torpedo body would be a slick little package, looking like a tiny MAG.
Hi Cataract,GUY: have your tried with much weaker magnets? You might also want to get them from a source that can certify the magnet's strength for a more uniform result.
hehe, no need for punishment flashfloodOh, I know. Just couldn't resist: pentagon, star, pentagram (devil), etc.
LOL, its totally fine of course. But the flashdark code is floating out there somewhereThere you have it Guy, FlashFlood has volunteered to get the absolute very last Torpedo you ship. He can wait til everyone else gets one for being facetious.
Ahh... yes, exactly what I was thinking.Don't say that, it might invite the flashdark mode!
Always a much safer option.he waited until AFTER it arrived to say that
http://www.candlepowerforums.com/vb...gress-Part-2&p=4372491&highlight=#post4372491
Thanks Dale, and I need UNI back here double time to help out when he's done :thumbsup:I'm so sorry to hear about the recall on X024, what a shame! But you'll get it's replacement, sometime or other...
Thanks for the heads up cnlson, we'll get Uni dispatched right away to pick up that "defective" X024 unit.
Reporting in X090.
I have been using it exclusively with AAA eneloops. I did a not very precise run time test on level 3 today. It lasted about 4 hours. The cell took a charge of about 750 mAh according to my Maha charger immediately after the test.
I have been carrying mine all the time with using pocket carry. It is holding up very well and it has never accidentally turned on. I have had no issues with the battery running down when the light was off. I have not yet had the battery run out unexpectedly. I have been putting in a fresh battery every 4 or 5 days whether it needed it or not. I have not tried an alkaline cell. I have not tried the short body in the extended position either.
Guy, do you have a cause for the instability of the direction of rotation that increases or decreases the light output? Sorry if you already explained and I missed it. Is the logic losing track of the direction of rotation or is the sensing not reliably sensing the direction of rotation? In my work we use sensors with 3 hall elements to sense the direction. Only two are necessary if the field levels are consistent enough, but having 3 allows for using the change in field strength and for self calibration of the transition thresholds.
I have a couple of thoughts on the final UI design. I really like the originally described UI with one direction of rotation increasing the light output and the other direction decreasing the light output and with lockout achieved by extra rotation in the off direction initiating a requirement for long travel in the on direction to turn on. If the two different rotation levels for off to on transition are not possible, then I would be happy with always requiring a long turn for the off to on transition. If the increasing output direction is always the same, then I don't think there is any need for detentes to be added. I wouldn't mind a physical stop so that rotation was limited to 360 degrees, but I don't think it is required.
The idea of instant access to high from off is somewhat appealing, but for me it is less important than maintaining the simple UI of one direction for more light and the other for less light.
I have had no issues with accidental activation or parasitic drain in the off state. Someone stated the opinion that a physical breaking of the battery feed circuit for lockout was required in order for the light to be acceptable for EDC. I disagree. If some kind of physical disconnect is added to address this desire, I would not want it to be a justification to complicate the interface. I don't want to have to use some secondary switch that would compromise the elegance of twist for on and twist more for more light (with on and more light always being one and only one direction) and would compromise the ease of single-handed use.
Hi GL,Agreed. Flashdark mode is a prestigious tight closed group, only available by accidental invitation.
Perhaps as Cataract has said, there needs to be a more harmonious effect between the hall sensors and the magnetic ring. With my limited understanding of hall sensors, perhaps some sort of shield between the magnets and external magnetic fields may solve some of the accidential activations and mode changes.
I also think that perfecting the 90 degree, 3 position and off makes more sense at this development stage than decreasing selections by 18 degrees that may add to complexity of the UI as it is now. Being the Torpedo's tight space, I think the addition of more sensors, space provided, could solve many of these concerns.
Example, if the ring direction of turning were to determine advancing and decreasing modes, that would solve some troubles. Another benifit could be how fast the ring is turned, Meaning that if I turn very fast in increasing or decreasing modes, it would advance only one step at a time even if the ring were to be turned 180 degrees. Turning slowly would allow less degrees for mode changes.
Turning one direction for high from Off and the other to Moon sounds very appealing.
GL
I sure enjoyed it but it's been misery for more than a few folks, though most things seem to be back to normal.Great to hear the progress, amazing journey for sure.
Sorry to hear about the storm of the century, must be bad for a whole lot of people.
I know I'm a nut but I enjoyed all the shovelling too.At first I thought you were digging a secondary 42 minute travel hole LOL. Well, it's not funny, I know what shoveling snow like a maniac is like and it's the worst thing to shovel; it doesn't do anything to get you in shape and it feels like it will never end unless you have a heart attack first. I largely preferred shoveling gravel as you do see the progression, and you don't feel like you're huffing and puffing for no reason. Those days are way behind me, though.
Haven't had a chance to do much with my flashdark yet, but hopefully tomorrow. Work has been crazy with follow-ups lately and the pile just seems to grow faster than I can finish just one case. I might be doing some shoveling of my own just to see my desk...
Snow is a little less dustyI guess I prefer shoveling gravel also. It usually is not 20 below(-28C) like it was last night.
GL
I started out with multiple layers but was down to a t-shirt within 30 minutes.And your feet don't get freezing wet. Some people complain that you can always dress warmer in the winter, but we only have so many clothes to take off in the summer. I say when you can only move so much to prevent hypothermia, while a heat stroke is easy to prevent by laying down in the shade with a drink Guy: when's that extreme infra-red light coming out? I thought it was supposed to be in an HF head format... what do you think I got the Cu for? We also need it in toe-pad format that fits inside boots :laughing:
Thanks,@tgwnn: something I forgot to mention: my precious (X024) doesn't seem to have the parasitic drain issue that other folks have mentioned. I'm using the short body with the new (black) MBI nuke 10250. After three days of light use, the battery is still at 4.12V. Just FYI, in case the lack of problem on this serial number tickles a neuron as to why others are affected and this one is not.
Of course, I would find them frustrating too and those issues are not s'pposed to be there.My x073 does not seem to have the drain issue either, but when I turn it off, I always leave it lined up with a dot. The inconsistencies in UI direction are frustrating when trying to use it one handed. And i dislike having to look at the light to shut it off.
I also don't note any parasitic power loss.
guy, quick question, what battery levels are required on the LIONs for the various output levels? for instance, what is the min voltage for stage 4, 3, 2?
keychain keeper for spare nuke, been in the works for some time but just a metal tube with no electronics....
so the electronics are nearly ready now (functionally perfect, just adjusting layout/size), and I hope that means the keychain keeper is not too far behind.
