5mm LED display
Qoose
Between Seattle, LA, and Boston
If this isn't quite the right forum, feel free to move. Flashlight is defined as a battery powered light source though...
I'm sure many of you have heard of LED throwies. If you haven't google is your friend. Another way to think of it is a keychain light, only with no plastic shell. Now I want to make a simmilar little guy, only using a CR123 and possibly a resistor. I want it to last for at least a few months. I'm using this to make a cool display, and no it will not be graffiti/harmful to the enviroment. It only needs to be bright enough that the LEDs can be seen when looking directly at them.
Now I already made a prototype, run off a partially drained CR123. Using a really nice multimeter that I got as a gift, I found it drawing 2.8ma. If this was constant, then it shouldn't have lasted more than 200 hours assuming that the battery was under 1/3 full. However, it glowed for about 3 weeks. I didn't meter it when it got darker though, so I suspect that current and voltage dropped which let it stay alive for much longer.
I was using a used Tenergy cell without a resistor. I strung one LED lead through the vent holes, twisted and glued. Then I peeled off the wrapping, and used the body as the negative contact.
My question is this. Is it safe? This is a tiny load on the cell, but is there any chance of a venting/meltdown? I don't want my piece of art to become a bomb.
Next, I'm thinking of soldering my next ones together, but just the positive contact, to the lead. Would it be bad if I soldered to the battery?
Also, would a resistor burn off energy, and would it be better to just find the dimmest LEDs I can buy, and drive them directly?
Last, where is the cheapest that I can get 50ish cells, and would these cheap cells be safe under this tiny load?
