OK, would the above outfit work? From "LuxLuthor's" tables it shows; 21V, 5.5A, 6700 lumens, bulb life 4.8 hours. I admit, not a very practical light but impressive in show and tell......Would this need two clicks to start up?
I have done exactly this. How? Mag 4D, with a Modamag D extender, kiu socket, boro lens, FM dual mode reflector, a homemade spacer to make up the distance needed, an 8 1/2 x 11 piece of paper rolled up to generate a simple "holder" of sorts, and of course, 5 of AW C-lions. I will say it did not work all that well, as I had to have multiple clicks to get the light to turn on. It could be that my connections were not totally 100%. Darn light was bright as all get out. I figure that when it was on, I was getting something like in excess of 3000 torch lumens (using the 65% factor) at or near the start, say, with 17.5volts to the bulb; toward the end, at about 15.5 volts, it was still getting an estimated 1990 torch lumens. By the way, while you might get as much as 3.7V per bulb at the start, or 18.5V, that will last only a little bit. 3.1 to 3.5v per battery is what I figure for the c-lions. I agree with mudman cj in that you will not get 21V to the bulb.
I did not do runtimes, but my estimates show about 30 min. of run sequences of 1 to 2 minutes each. I never did do a run over 5 min. and did it ever get hot!
What is interesting about this setup is the computation of lumen hours. At 3000 - 2000 torch lumens, or an overall 2500 avg. over a run sequence, running for 30 min., you get 1250 lumen hours. This is intriguing. Comparisons: ROP low for 1 hr. = 300; ROP hi for 30 min. = 300; M6 with MN15 at 200 lumens for 2.5 hrs. = 500; Mag 64610 at 1300 torch lumens for 23 min. = 571; Mag64623 at 2541 torch lumens for 10 min. = 424.
Have not tried to do any more with this, as I have been satisfied running my 64610 in a 3D+extender with 4x c-li-ions and an AWR hotdriver instead. This setup runs for over 25 min. with 1300 very white torch lumens. Because of the color temp of the 64610 it appears in my eyes to be almost as bright as a 64623 or even the mighty 64625 on 11 AA cells. To be honest, I could not tell the difference between my 50W 64610 beam color and the IRC 50W color. One reason is that the 64610 design spec is temp of 3400, compared to 3000 for the 64440. Even drastically overdriven with 5 cells, the IRC bulb still is a bit less than the 64610 with 4 cells. Moreover the 64610's cost $2.50 each versus the 64440IRC at $8+.
In closing, I should like to say that I am planning my next hotwire indulgence with D-lions in mind. If you could get a max capacity of 5 amps or better out of a D-lion, that means if it can handle 2x loads, or 10amps, the potential is there to run some pretty bright bulbs for at least 20 min. Example: you might be able to get 1 hr. out of a 50w bulb drawing 4.5 - 5.0 amps in a theoretical D-lion setup. This gets really interesting to think about. If all you want is a retina-searing light to run for short bursts (bump in the night, etc.) this could be a very good alternative to $300+ HID lights. As an example, you could configure a 4D setup for $200 - $240, including 4 D-lions. (body, metal reflector, glass lens, 4 batteries, kiu switch mod)
Regards to all.
Steve
