It's high time for an update. Sorry I've been remiss; I've been working on the field tester M6-R packs and chargers. Details on that subject are posted in the field tester thread, but the short story is that I am behind schedule and have only finished Catdaddy's charger at the moment. His pack will be completed tonight, and pyro's pack and charger will be done in a couple days, assuming that everything goes smoothly.
A few technical subjects: Willie Hunt's LVR3's have a 20K resistor across the power FET gate and source which lowers the gate after power is removed. This is so that the gate doesn't stay halfway open when power is removed from the LVR circuit, because if that happened, the FET would burn out almost instantly because it is meant to be either open or closed and is not able to dissipate the amount of power which would be dropped across it if it were in a half-open state.
Now, in the M6-R application, the LVR is always powered up because it is integrated and hardwired into the battery pack. So the only time R3 would come into play is if someone left their M6-R turned on. In that case, when the voltage of the pack dropped past 5 volts, the LVR would not have enough voltage to power itself, and would possibly go haywire, and would normally shut down, and then the voltage of the pack would rise, and the LVR would turn back on and try to draw more current from the pack, and so on until the pack were destroyed.
So, on Prolepsis's, Catdaddy's, and pyro's pack, I have left off R3 entirely because I would so much rather change out the $5 IRL 3803 power FET, than build an entirely new battery pack--so much more labor and cost involved in that. What I'm saying is that if the LVR ever gets to the point where it doesn't have enough voltage to function, I really want the FET to blow, as it will save the pack.
Plus, leaving off R3 means that there are only wires to and from the FET on the back, exposed, side of the board, and I like this.
On another technical topic, I have been "plating/coating" the copper, rounded triangular end-caps of the packs with a 96 percent tin and 4 percent silver lead-free solder. This is electrical grade solder, which means it conducts well, and it is nicely resistant to corrosion, and it is the hardest of the soft-solders.
However, it is not nearly as hard as I would like it to be, and I am always looking for ways to improve my designs, so I have been investigating the so-called hard solders, which are brazed on with a torch, instead of soldered on with an iron. I found some really good stuff, which conducts better than copper, is specifically used for making contacts out of pure copper pieces, and which is still low enough temp that it will not change the conductivity of the base copper. This means I get to play with an oxy-actelene torch. hehe /ubbthreads/images/graemlins/evilgrin07.gif Should be fun. Anyway, I will be using this on pyro's pack, and if all goes well, it will be the standard for the production packs.
Don't get me wrong, the tin/silver solder works fine, but it does get dented by the springs, and for some reason that bothers me a little, so I hope this hard solder will work fine. I don't see any reason why it won't.
I haven't edited the first post in this thread with an updated summary yet for precisely this reason: I'm waiting to see if this new contact plating will work out. Plus, I'd like it to have pictures of the charger with a glass epoxy printed circuit board instead of a phenolic proto-board.
And that's the weekly update. Thanks everyone.
