So, I found a universal switching power supply that will work anywhere and will provide enough current to power the CG-340, but not enough to power the Triton. But the good news is that it will cost $20 less than the power supplies which will power the Triton. All together, I think I could offer the Hitec CG-340, power supply, car adaptor, and charging cable for around $65 or so, but it depends on how much I can make up the car adaptor cable for. In any case, certainly for less than $75 all totaled.
I have reconsidered removing R3 from the circuit because when the LVR reaches 5.5 volts it cuts out to get enough power to itself to work, and then will try to run the lamp, and then will cut out, and so on, and this will eventually destroy the battery pack--true--but there is a decent length of time to catch this, and I'd rather risk a bit of performance loss to the batteries, than damaging or destroying the FET. The former is no big deal. The latter is a very big deal, in the sense that the pack would have to be returned to me. Of course, leaving the light turned on long enough will destroy the pack, but I'm guessing that people who have spent $300+ on a light and $110+ on a pack will have enough presense of mind not to do this. Plus, chances are that if there is no R3, BOTH the pack and the FET would get damaged in this sort of scenario.
Now, I think I have found a good shock isolation and rattle solution: small rubber bands placed towards the top and bottom of the pack, underneath the shrink-wrap. I'm going to try it out on pyro's pack and see how it works, but I'm guessing that this will be just the ticket. I suppose I could have called them "shock isolation bands" or something, but, nah, I'll just tell it like it is: they're rubber bands. /ubbthreads/images/graemlins/crackup.gif Hey, if it works, right? Plus, no one has suggested anything else, and foam thin enough is likely not going to add enough cushioning. Felt might also work out, but again, felt thin enough is likely not going to provide as much cushioning as the rubber. And for some reason these rubber bands that I have are the perfect thickness.
I know I'm not an impartial judge, but to my mind, the M6-R is just about the most perfect hand held non-EDC incan light there is:
1. It is BRIGHT,
2. It has a FLAWLESS beam.
3. It has throw AND spill
4. It is regulated.
5. It is rechargeable.
6. It is shock-isolated.
7. It is hard anodized.
8. It has a rear placed LOTC.
9. It is relatively small (2D or less size).
10. It is water-resistant / dunk-proof.
11. It has an optically coated pyrex lens.
12. It is beautiful and well proportioned and good to hand.
I told my wife that I would sell my M6 after the completion of this project, to make back the $300 investment, but honestly, I just can't give this light up. I've decided that there's no way I'd sell unless I was really hard-up for cash. Because I know I don't need it. But still.
