HI CPF people, is my maglite a bomb?
I have a MR16 mag setup which utilises the above mentioned 9 in series cr123a at 3.6A giving 61W fresh. To date all use has been in burst mode of 15seconds max!
Preperation includes Flash-amp matching of cells and regular removal and retesting (monitoring) of all cells. Initially i even combined brands but still matched (flashamp) cells and had no real issues but did note resting voltage curve and recovery differences. My biggest change came about when on 2 seperate occasions, 1 SF battery in the string shutdown, and stayed dead, reading 2.7+ volts, but dribbling .1A.. Since i have stopped using SF in this torch.
I have now had 2 full sets of Titaniums over 3 months in use (all burst mode) without drama. Im confident with this arrangement, yet am being cautious. Its not something to give to a friend for christmas... Yet
I have searched and read up both great Lithium battery reviews by Silverfox (i think/thank/sorry if im wrong) and also scary venting/explosive stories.
Does anybody else have experience with similar power supply arrangements as i have setup. I am interested in long strings of Li cells, and similar or greater Current draws. Realistically, anything you think is useful, would likely be, so please jump in. Is it possible that the ends of a long stick drain or heat unevenly? (This is one thing iv never answered, but have thought about).
I think the surefire N62 lamp assembly uses 4 cr123 cells for 500Lumens, so think that has a similar current drain, so a commercial product with significanltly higher than 2A drain is available, but I have noted it is a burst use device. If there are any long run users of this N62, please jump in with comments and experience.
Is my cautious side just being overcautious. If so it is my left side, because the right hand always carries this maglite
but its definitely kept me safe.. If anyone can comfort me, with experience of similar safe abuse to cells, I would appreciate it, as ultimately i would like to know its safe for longer runs.
Otherwise, thanks and take care
aerosimon
aerosimon
