Hi guys,
Background:
Recently I got myself a SureFire A2. Thanks to SF
policy I've been forced to get a second hand one.
It's the RED LED version. I thought myself that I
could live with that, but I can't. What I'm also
not able to do, Is to get a White LED ring for it.
So, swapping the LED's seems to be the only option
for me. And I'd like to do it myself
I've already found out how to do it. But now I have
to choose some LED's, unfortunately I'm completely
unfamiliar with that market.
What I'd like to get, is a warm 2 to 6 lumens white
floody beam. The LED's should be far from overdriven
(if possible).
The red led ring uses 100.4 Ohm SMD resistors, that
as far as I've found are responsible for the ca. 25 mA
current flowing through the 5mm LED (I might be wrong).
I must say, that I would like to keep the stock resistors
and swap the LED's only. But if a needed....
Can You propose me a good 5mm LED for this task, and
a source where I could buy it ?
Background:
(if possible).
