Re: Brass LS AAA lights - Make me an offer!
Hello Dave,
When I first saw this offer, I asked myself "Who would want a square beam?"
Since you were offering a brass version, I decided to give it a try.
I still get comments about the square beam, but I have been carrying them with me for the last month and have gotten quite use to it. There are a lot of times when a flood type beam is best for close up work, but I have found that there are just as many times when a small spot works better.
I love the tint. Very white (with a golden halo) and the spot is great for looking in cracks and behind and under furniture. The spot is tight, so it is not a good general walking light, but more of an area of interest light. It has good throw as well.
I have had two "problems" with my lights.
My Saft NiMh AAA's did not seem to make good contact at first. I tried several primary cells with no problems, but when I used the NiMh's the light flickered. At the risk of breaking the light, I tightened down a bit harder and everything worked fine. I have been using it in this way and everything still works. It is a bit hard to turn completely on "one handed" but is very manageable. This is not an issue with primary cells and may not be an issue with other NiMh cells, but I have not tried other cells.
The second issue was with the beam back spill from the ball. I found that by putting my thumb over the edge of the light, or holding it out a bit in front of me, this was no longer an issue.
All in all, a great modification.
Thanks.
Tom
