Dark Vapor
I was reading the thread on the Dereelight with the SSC P4 LED where you turn the bezel to focus the beam. Earlier today, I received the Lumapower Tactical M1 Hunter and changed out the OP for the smooth reflector and noticed a locking ring to hold it securely in place. Not sure if the original M1 has this. And oh yeah, also changed it to the 2 stage switch. What has this got to do with being able to focus the beam you ask? Okay, so you don't care.
Anyway. Reading the thread, I remembered about the locking ring on the M1 and wondered if the beam could be adjusted by turning the bezel. At about a distance of 10ft, I doubled the size of the hotspot before the donut hole began to show. The smooth reflector has three rings; the OP should smooth this out (someone else can verify this). You're actually unscrewing the bezel and on mine, it needed only about a one-half revolution to get it to the largest spot (no donut hole). I'm pretty sure this wasn't a "built-in" feature, but I think it would come in handy when you need a flood instead of throw.
Has anyone noticed or tried this? Bad idea?
