I received my Airbike EverlightSSC P7 headlight through the post today, seven days after purchase.
The Everlight is a Korean made light available from Airbike.kr and is also marketed on EBAY. The manufacturer claims the following specification, cut and paste from the listing:
1.SSC P7 Led light with 3 cells Li-Ion Batteries
2.Color : Black, Blue, Gold, Red
3.Weight : 398g( Light body, bracket and battery )
4. Mode : 4 steps( Low[375lumens] => Normal => Flash => High[670lumens] )
5.Burnning Time : High mode( 670lumens, 3 hours ), Low mode( 375lumens, 5 hours )
6.Batteries : Li-Ion batteries with 3 Cells
7.Charging Time : 4.5 hours
8.Charger : 100Volts ~ 240Volts
9.Bracket : for 25.4mm & 31.8mm
The physical appearance of the light is smart, and its small run CNC origin is obvious - more "Paul's" than "Shimano". The anodising is even coloured and the milling has no burrs.
The light is controlled by a small rocker switch on the rear:
It is fitted with a deep smooth reflector of about 37mm diameter. The emitter is slightly off centre.
When switched on and off the light Cycles (oops) through the following modes: High Low Medium Flash. It appears always to cycle to the next mode irrespective of how long it is left off or how briefly it is switched on.
The clamp allow for mounting on a wide range of bars and appears secure. It is a little shabby in appearance compared to the lamp body and bezel.
The unit is sealed with a single o ring at the lens. There is no seal on the switch or bezel thread although an external o ring shields the join between the bezel and the lamp body.
First impressions of the beam indoors were that it was a little ringy and that you could see the four dies of the emitter within the pattern. In the outside world this is not obvious and I do not think one would notice on a bike. The beam is not tightly focussed and had far less of a hot spot than my P7 MRV. Beamshots will follow. A ceiling bouce test suggest that the output on high is similar to my direct drive MRV P7 with fresh batteries.
The battery pack is a very tidy bundle apparently composed of three 18650 cells in parallel. I do not know if it has a protection circuit. a 4.2v smart charger is included. I have not yet tested the battery life.
