ALL SOLD WTS: TK75vn
Status
Not open for further replies.
Skylumen
TK75vn
- 3400 LED Lumen
- At least 3000 Lumen Out The Front ( not measured so I don't know, but its much brighter than stock)
- Upgrade to around 3.8A on High per LED Factory is around 2.8A
- Low and all other modes and UI are as factory
- Thick copper sink pad allow great heat sinking
- High Quality Thermal compound
- Hot spot is defined and bright. Spill lit up the night too! Massive Lumen in a high quality package.
- This is a light up everything in front of you and beyond light. Just so much lumen you will be shock!
- Connections tweaked everywhere for better current flow
- LED surrounding cleanly finished to exposed copper square for good looks.
- Light bought brand new for the mod. Comes with everything as new.
- If you are not impressed by this light performance, I would be curious as to why. :-)
- Dome on for large round hot spot and max lumen count (Recommended)
- Dome off for Max throw
When order please choose from below:
A) Dome or De-dome
B) XML2 T6 5000K or U2 6500K
$220 Shipped Priority USA.
+$25 Shipped International First Class.
TK75 XM-L2 6500K VS TK75vn XM-L2 6500K
1) JKR
2) Tly
3) Superpila 5500k dome on
4) Sold A1
5) Sold A1
6) sbbsga cpf T6 5500K dome on red top engrave on head
7) Kenny
8) Eric 5500K Dome on
9) ---------------
10) PhatPhil 5000K 3C
A. JAMALI 5000K
B. JAMALI 5000K
C. PearlPower 5000K
Re: WTS: TK75vn (2 LEFT)
Fenix says 2900 lumen. So this is only 500 lumen extra? You have any comparison photos of X40vn and TK75vn beamshots?
A Big Big Thanks to those that have been very very patient with this sale. The lights are finally here!!!
Will these come with the original box and plastic case?
Too foggy outside so I did indoor beam shots instead. Check out post 1.
Booyaaaah!!! They made it. That's GOLD!!
Foggy outside huh, that's when you need the Mvn. That was one of the main factors that convinced me to get the Vostro vn.
Shame this one can't be bumped up to 5amp :)
Vin, I really think it would be a great idea for you to start using gif animation for before and after shots, this way people will see the improvements to your mods so much better. I have noticed many people seem to find it hard to see the difference with the pics side by side
If it could be bump to 4.5A then its on my Must Have list a long time ago :-(
How do I do gif animation?
Good question! It should be pretty simple. i have to go out, but I will find out when I get back if no one beats me to it. There are many that are quite talented in this forum :)
I'd like to order one. Dome on and 5500K.
I see, no wonder! Is it because of the aluminium base, MCPCB?
Its copper but the Driver wont allow for very high Amp boost. If I boost the Amp real high I will start to loose modes. IIRC the light becomes Low-High Only at 4.5A. :-(
Oh well 3.8A is not bad. Good practical light :-)
I see. That is too bad indeed. But the vn is still awesome! :twothumbs
Sent from mobile device.
TK75 vs TK75vn - white wall test (brown wall Lol)
TK75 vs TK75vn ceiling bounce
Now we can really see the difference in brightness!!:clap::buddies:
When comparing different lights it is much easier to tell the difference in the beam when the images are side by side compared to two of the same light for the beam pattern is the same.
Excellent! Christmas will be coming early :)
Could not find info on runtimes. Are the runtimes significantly reduced after the mod? What runtimes can one expect to get using 3400mah batteries?
Runtime drop abtou 25% from factory specs
Status
