Could someone please confirm if two of these boards CANNOT be driven in series from two LiIon batteries?
I'm building a couple of lights for my camcorder, using 50Led bike lights from DX. I got 2 pairs of 2 LiIon cells from a laptop battery that should've given me 7.2V at 3800mAh. Batteries show 7.8V fully charged. I connected a single 50Led light using one of the 800mA controllers from DX:
3.6V~9V 800mA Regulated IC Circuit Board
I got decent light output for about 2Hrs and change, the voltage at the light was a solid 3.3-3.4V, but then it started dropping rather quickly, down to about 3V after 2.5Hrs, at which point I just turned it off. I guess I should've measured current instead... Anyway, with 2 lights (on two separate boards, of course) I'd get just over an hour of usable light, bummer... These ain't new batteries, so maybe that's the problem? I also noticed that the board gets quite hot.
The reason for 7.2V instead of a single 3.6V is that the 4.2V charger I have is only rated for 800mA, while my 8.4V camcorder charger is 1.5A.
So, if I can connect two AMC7135 in series, this may solve my problem of having to rig a new charger.
TIA - ardo.
P.S. Amazing forum, I wish I knew about it sooner!
TIA - ardo.
