SilverFox
I think I may have a record here...
Aircraft800 sent me some Sanyo 2700 mAh cells. He cited that they had developed a high rate of self discharge. I told him that I would like to take a look at them and ended up with them.
I ran a couple of Break-In cycles on them, and they came in at around 2200 mAh. Since Sanyo lists the 2700 cells as 2500 mAh minimum, this works out to around 88% of the original capacity, so that seems pretty good.
I put them aside for a few days and then checked them again. They were down to around 0.9 volts and were dead. OK, that seems to be accelerated self discharge.
I decided to charge them back up and do some more testing on them. There really isn't anything that can be done to reduce the self discharge rate, but I just wanted to play around. I charged them up and left them on the charger to trickle charge. The next day I decided to do another discharge.
Wow, was I surprised...
Sitting on the charger trickle charging overnight (well a low trickle charge as I was using a C9000), I lost over 500 mAh of capacity!!!
These cells are beyond crap... they are junk.
Aircraft800 I am sorry you wasted the postage on these cells...
Tom
Tom
