petrev
Hi
First off
Big Thanks . . .
. . . to JS for the original M6-R (and pointing me to where to find an LVR3I)
. . . to wqiles for his version and pictures
. . . to tvodrd for letting me have his spare Willie Hunt(JSversion)LVR3I
JS reference for LVR3I - No longer for sale - M6-R LVR3I PWM regulators
JS Original thread M6-R
Wquiles excellent version Wquiles~M6-R
Willie Hunt's specs. page Lightbulb Voltage Regulators
Other items incorporated in this build . . .
Petrev XTN36
Fivemega alternative extension FM52+
Andrewwynn modified Tail Switch Insert - AWR-TailCup
e-mail Andrew
So I had to make up a new regulated pack after I improved my PIR-Pack to death !
Here's what I wanted . . . 3s2p-17670 Li-Ion pack/carrier - Neg at the middle of one stack (1/8"brass rod links 2 pos ends to the head end) and then two stacks of 2 in parallel fill the triangle to the tail end. Second 1/8"Rod carries Batt-POS to tail (it's already there actually but I had a spare rod !) and the 2mm Rod carries NegBulb to Head-End. Battery nodes readily available for when I finally get a balanced-charger . . .)
Method . . .
Cut 3 disks from copper PCB stuff - I used a 35mm holesaw for the smaller disk and a 38mm holesaw(Bosch wood type) for the 2 bigger disks - if you cut them through a piece of pre-holed wood then you can dispense with the centre bit and thus there is no centre hole)
Drill 2 3.2mm (1/8") holes and a 2mm hole
Mark up the expected layout . . .
Bulb end on the left and all facing the same way (Head UP)
Tail UP at the right
Like sides together - Head End
Like sides together - Tail End
Try it all out for size - (Thanks to tvodrd for the great little box he sent the LVR3I in) and add some of the wires . . .
Mark out Groove lines . . .
Proximal sides together
View from the tail end
View from the head end
Cut the grooves and solder the bits on - Slip on some shrink wrap . . .
(Note moved the Neg-In connection point to the other side of the cutout at final assembly as a safer place for it to be)
More heat shrink and then solder it up
Lots of tweaking to get the right length etc. and see how the centre disk floats and there are only springs on the head end section - all cells point in the same direction except the one in the left section with the spring letting you know its the one ? ? ?
Black wrapped wire is Neg-In, Red is Pos-In and Red/Black is Bulb-Neg-Out
Join it all together . . . Cut the excess bits off and tidy it up
Add some of AW's Protected 17670s (turn it round just for a change)
Tape on the Tail-End
Tape on the Head-End
It Works ! ! !
First off
Big Thanks . . .
Petrev XTN36
e-mail Andrew
Method . . .
It Works ! ! !
