spc
I love re-building these Arcs... The Body on this one is one piece -not with the removable bezel like the first runs.
For this build I chose a neutral cree XP-G (3a r4) nice 5000k color
I wanted to use the stock board for great runtime.
Here are the parts:
The board was already modded with a newer lux, and it popped off easy
then the ims17 reflector and a glass lens..
I had planned on shaving down the xpg board so it would fit in between the components, but decided to shim it above them (less work). I made the shim out of a small piece of copper.:
Here it is thermally epoxied down on the shim and then wired up:
I shaved the solder joints a little to make them flat. This way the reflector and board will rest together nice when tightened. Also orange peeled the reflector. (I wanted a nice smooth beam with some flood to make this a very usable edc)
Here she is put together:
Hope you like, i'll post more phots/beamshots later
Here are the parts:
