march.brown
Any small torch can easily be used under water ... For example , the iTP A2 will run for two hours on maximum and seven hours on medium ... Switch the light on immediately before you dive , put the torch into a small glass Sauce bottle or similar with the LED facing down and screw the lid on ... As long as the glass bottle is small enough to grip easily , it will work OK ... And with the lid screwed on tightly , it is waterproof.
I wouldn't like to use this method on a high power torch because of the lack of heat transfer.
