PhotonWrangler
I picked up a 2AA MagLED today hoping I can use it as a host for another LED, but it looks like the LED module is crimped into the tube somehow. Has anyone managed to extract the LED module without destroying it?
I had disassembled one quite a while back. Thankfully, I saved the write up I did on it so I could go back and double check my memory. If all you need to do is remove the LED module, it just pops out. For disassembly, first remove the batteries and the head. Then I used two small screwdrivers to push down on the metal case of the LED module where it is visible through the slots in the plastic retainer. It took a fair amount of force, but when it popped loose the module just dropped out the bottom.I picked up a 2AA MagLED today hoping I can use it as a host for another LED, but it looks like the LED module is crimped into the tube somehow. Has anyone managed to extract the LED module without destroying it?
Do you still have the pictures? I can put them on my Photobucket host and quote your post with the corrected links to them.I found my original post from two years ago where I did the disassembly. The picture links are dead, but the description remains.
