kosPap
just wanted to know your experiences with this light....
Is it true that it is direct-driven?
thnaks, Kostas
thnaks, Kostas
Although it might just have a dropping resistor like an MTE light I got from DX. I replaced the resistor with a 3X7135 regulator and use a 17650 for power, and it makes a pretty decent inexpensive light. But I don't know about the C2.I don't have one so I'm not 100% sure but... 18650 version might be direct driven..
The 2 x CR123A version cannot be direct driven for obvious reasons.. (too much voltage) . . .
It works nicely with 7.4 LiIon...
Fact that it works with 2 x CR123A means it is not direct driven.
But there are two version of the C2 Q5. Multi and single voltage.
So the 18650 version may be direct driven with 2 mode switch.
Hmm. Now that I look for one. There isn't a 18650 "only" version. =P
But.. Someone at DX mentions that it is slightly dimmer with 18650.
Someone else says the brightness stays the same even with 18650.
So it does work with both 18650 and 2 x RCR123A batteries it seems.
