Wash test results. Cold cycle with darks, then into the hot cycle/bleach with the whites. Then into the drier. Still ticking. Later this evening, it will go in with the lights through a warm wash cycle, then into the drier.
BTW, my EDC AAA standard has seen several inadvertent wash/dry cycles with no ill effects. I don't expect the newer versions to be any different. This is kinda getting boring. I'm starting to think about launching it out of a twelve guage. But launching it into something "soft" without losing it. That's the challenge. Also, how to do it. Take some birdshot out, place AAA inside, close the shell securely, chamber then fire into soft backstop? Peter, what do you think? Too extreme? I'm not sure it will survive but so far nothings fazed it including more throws against the tile floor. I haven't been able to get the rivet loosened either after probably several hundred twist on/off cycles. I'm on my third cell since the other two got crushed.
