hate to say it, but ARC AAA is not about beam quality. if that's what you are after, you will be disappointed.
what ARC AAA has always been about is best compromise of size, function, reliability, HA finish, cost, runtime, output, etc, etc.
ARC AAA is not the best at any one thing. but the best compromise of the above.
it's a real design front runner! it's flat amazing that ARC AAA has been world's best 1x AAA light for so long. loads of different lights have tried to dethrone ARC AAA ... so far no one has succeeded.
with Cree coming out, it's super low VF has allowed mods of ARC AAA to way surpass ARC AAA's performance and at same time keep it's timeless form factor.
highly recommend a Miller mods Cree two stage ARC AAA mod. using genuine ARC AAA head and body. yes there is a difference!
the next Paradigm shift has arrived in cree's performance and beam pattern. which is perfect for no optic applications. low vf allows use of std alk or NHM AAA cells.
this combined with a two stage twisty, makes the most ideal user interface available.
it's high time Peter took a closer look at CREE based two stage mods like what Miller mods has been putting out. enough units have been in the field to prove reliability of two stage switch design.
with current set to 50/200 milliamps, you get super long run times and high output. heat is not a huge factor at these low currents.
hey Peter... sure hope you are listening!
folks would line up for a ARC AAA XR-E two stage
