Last November I bought two DS, one for me and the other for a friend that is deployed to Afghanistan. This week my Arc started to do strange things. First, it suddenly went down. I thought that maybe the problem was with the contacts. I cleaned them and it did not work, then I changed batteries and it worked, so I thought the battery charge was depleted, although it did not go into "moon" mode.
I put the old battery back and to my surprise it worked. I switched it on on off a few times and it still worked. After 1 hour after switching it off I had the same behavior (works with new battery and with the old one back and after a while it does not work with the old battery). The problem is that I think I am getting less runtime than expected since it suddenly shuts off.
Any suggestions? Should I send it back to Arc?
