the AS is composed of Silver, Boron Nitride, Resin, and Hardener. The resin and hardener is a polymer, haven't looked into the chemical composition of the resin and hardener but it's highly likely that you can remove it with MEK (Methyl Ethyl Ketone). MEK is used in the plastics manufacturing industry for deburing and bonding, MEK will breakdown most polymers at a moleculur level, when rinsed after application it's deburing, if left and conjoined with another plastic with similar property it adheres. since it's attached to a heatsink and the LED should be glass or glass filled polymer, MEK should breakdown the resin/hardener in the AS and remove the LED safely without force.
