Asperical G2Z + FM34- 2 Lights in One!
Inliner
AZ
I just finished setting up a lens I found a Kaidomain in my G2Z. It took some work to get the focus right, but it was well worth it! The camera is ancient, but you can see the detail in the LED on the wall. The FM34 diffuser is amazing. Smooth reflector, orange peel, regular lens or asphericall - all flood all the time!
My duty light:
Diffuser Open:
Diffuser Closed:
Should be dark soon... can't wait to see how far it will throw now. I'm using a cheap single mode R2 drop in. Need to replace it because after about 5 minutes it overheats and shuts down. Maybe a metal Z2 host would cure that though....
Flat on one side, convex on the other. When properly focused in front of an LED it gives the beam pattern shown above; a very intense center spot that gives great throw.
