Its possible of course, but the best led for using in combination with
the Aspheric lens is the Cree-XRE rather than the Seoul-SSC-P4 or P7.
This is because the narrow beam angle of the Cree means that most
of the light is being projected forward into the Aspheric lens rather
than being wasted with a broader beam angle like the SSC leds
The first image is the light focused with a 52mm x 37mm lens... The head needed to be unscrewed nearly all the way to get it to focus like this. If the head was left screwed all the way down, you get a bright round beam, like in the second picture, with very minor artifacts.
The same camera settings were used for both and had to be under exposed so you could see the detail. The wall (actually my ceiling) is about 8-9ft away.
They aren't. We saw this same inconsistency between dies from the low power picture thread. This is probably a reason why there is so much spread between bins. I suppose it could be a problem when the emitter is pushed to the limit since that would mean one die is getting close to the edge of destruction.
In those pics it was running at about 1.8A because the batteries were getting low. I was also holding the light in my hand because it wouldn't tail stand on the carpet so some movement might have caused the difference in brightness. When looking with my eyes, it was too bright to see any difference.
I'm not too good with outside beam shots but when focused the dies (dice?) are still visible at over 50m.
[edit] Here are some outside pics. The brightness isn't accurate but you get an idea of the beam.
Control shot
Wide focus with 52mm x 37mm FL aspheric lens. Distance is about 50m, I think.
Tight focus with 52mm x 37mm FL aspheric lens. Distance is about 50m, I think.
Tight focus with 52mm x 37mm FL aspheric lens. Distance is about 70m, I think.
Tight focus with 52mm x 37mm FL aspheric lens. Distance is about 20m, I think.
I'm not going to use it like that as I prefer the hot spot from a reflector but if I wanted a nice even floodlight, i'd definitely use an aspheric lens defocused.
